Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Alta Mini Performance
Old Dec 2, 2004 | 05:38 PM
Shawn C's Avatar
Shawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond reputeShawn C has a reputation beyond repute
I have Sway Bars otw.
Anyone here installed them? I hear it makes the handling unbelievable even without lowering the car.
Old Dec 3, 2004 | 06:37 AM
KSA Turbo's Avatar
P O R S C H E
KSA Turbo is infamous around these parts
a friend of mine has them and you sure do feel a diff
Old Dec 4, 2004 | 11:43 PM
tontobird's Avatar
tontobird is infamous around these parts
Most people only do the rear, are you doing both? From which company have you ordered?
Old Dec 5, 2004 | 06:27 AM
Shawn C's Avatar
Alta, and yes just the rear.
Old Dec 8, 2004 | 01:20 PM
tontobird's Avatar
The rear sway bar is one of the most popular suspension mods, the most bang for the buck, as one would say. Would love to hear your feedback when done. It's next on my list.
Old Apr 13, 2009 | 11:49 PM
dynamicss's Avatar
dynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these partsdynamicss is infamous around these parts
keep it on the rear. You dont need it in the front.. it's useless. If you put lets say 26mm front sway.. you have to put 25mm rear to even out the increase in the front.. 22mm in the rear is more than enough.... I hope it worked out for you.
Old Apr 14, 2009 | 08:03 PM
beaner's Avatar
beaner is infamous around these parts
the op now drives the lotus in his avatar. i've mixed it up w/ him a few times on the track.
Old Apr 16, 2009 | 08:31 AM
WJHMH's Avatar
WJHMH is just really niceWJHMH is just really niceWJHMH is just really niceWJHMH is just really nice
I just bought a r53 MCS & was wondering the same thing.
Old Apr 16, 2009 | 12:16 PM
beaner's Avatar
a larger rear anti-sway bar is a good addition. how much bar one needs is a function of use and other mods. the larger bar helps reduce understeer, but this can also be accomplished w/ more front camber, a stiffer platform, air pressures, etc. i have a 19mm bar on the middle setting. i run -2.5* front camber and hoosier r-comps. the car is generally neutral w/ this setup, but i can easily induce lift-throttle or trail-brake oversteer when desired (on the track of course).
Old Apr 16, 2009 | 02:19 PM
dynamicss's Avatar
Lot's of interesting information I did not know... I have my Hotchkis 25mm in the rear set up in the middle, and I dont track the car.. but the handling is awsome. I guess i'll consult with a couple of mini tuners in my area before I head out for the track.
PelicanParts.com
Sep 1, 2015 02:36 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
ECS Tuning - BMW
Aug 19, 2015 01:35 PM
ECS Tuning - BMW
Aug 19, 2015 01:22 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
