Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Weird scratching noise when starting
Old Mar 12, 2012 | 11:09 PM
mionallen's Avatar
mionallen is infamous around these parts
I just bought a Mini Cooper S 2007 and just recently when i start it i heard a weird scratching noise almost like a CD scratching (yes i checked if there was a cd in the player)
Any ideas?
Old Mar 14, 2012 | 12:07 AM
mionallen's Avatar
it only happens on a cold start i noticed
anyone got any clue what so ever? any help is appreciated
Old Mar 14, 2012 | 11:09 PM
mionallen's Avatar
Now theres an exclamation point with a triangle around it on my tach any ideas what that is?
Old Mar 15, 2012 | 05:23 PM
MkC2S's Avatar
that would be your traction control...there should be a switch say ASC or DSC...you must have accidently turn it on...did it on mine all the time when I lower the window.
Old Jul 16, 2012 | 08:32 AM
911Konigin's Avatar
911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of
Were you able to find the problem?
Old Jul 18, 2012 | 06:47 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
I had our '06 S in the shop for a routine oil change and a new battery (still had the OEM battery - talk about running on borrowed time ), and they had another '06 in there for an unidentifiable noise like this.
It turned out that the crank pulley was separating, causing the noise. The pulley cannot just be pulled from the crank like any other car, there are six special, mini-only tools that a shop has to have to fix this. That other '06 ended up on a flatbed and went to the dealership. God help him.
I hope this is not your problem.
Old Jul 30, 2012 | 07:26 PM
night_rider65's Avatar
night_rider65 is infamous around these parts
This is a fan belt voice for sure.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
