Nissan GTR Forum for the R32, R33, R34 and R35 "Godzilla"
valves?
Old Apr 6, 2010 | 07:05 PM
Me_qwkr's Avatar
Me_qwkr is infamous around these parts
valves?
Hey I was wondering if anyone here has used SuperTech.. I am currently going to do dual spring setup on my RB and the HKS kit is like 1200 and the Supertech kit is 500????? really confused why
Old Apr 8, 2010 | 01:12 AM
Skylin818's Avatar
Skylin818 has a spectacular aura aboutSkylin818 has a spectacular aura about
use the R34 RB25DET NEO HEAD = same and a lot better then the HKS V-cam set up. the head studs will need to be drilled for the RB26 head studs but you will be blowin away on the Power gain.
this goes the same for the valve train and its a solid lifter not a hydraulic ones as the early model Rb26's.
Old Apr 8, 2010 | 12:25 PM
Me_qwkr's Avatar
??? Never heard of this in five plus years building these cars.. I think there was a single tuner in japan that did that. I just want to prevent floating.
Old Apr 9, 2010 | 09:57 AM
Skylin818's Avatar
just follow what I said on the use of the head and parts much better then the aftermarket stuff. if its lighter then factory in the aftermarket stuff just remember it will not last. Worse 97% the after market stuff is not R&D tested where the factory spends years on testing it before it goes into a production car.
also look into the RD28 crank and 90mm bore on a RB26 set up
do not use the RB30 as its max rev you will get out of it is 6k where as the set up I mentioned us a RD28 crank + 90mm pistons and some carillo rods will give you the bottom end you want.
and if you can look into it = reverse cooling using and electric water pump set up.
Old Apr 9, 2010 | 10:06 AM
Me_qwkr's Avatar
Okay so honestly what are you talking about. The rb25 valves are smaller. I am not replacing valves but instead the springs and retainers. Also the rd30 is a waste of time and money when the bullet proof os giken is almost the same price.
My rb is already bored and built bottem end with very extensive head work. I hate to disagree with you but what is your goal 1400hp cause if not then your spending to much time and effort on a motor that is capable of doing 800hp reliable all day long.
Old Apr 9, 2010 | 12:38 PM
Skylin818's Avatar
Peace bro , I have no idea what I'm talking about.
Good luck with the build.
White991TT
Mar 8, 2016 06:01 AM
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 02:07 PM
