Need help
Old Dec 31, 2008 | 10:44 PM
mr2guysingh's Avatar
mr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to behold
Need help
Anyone here know a lot about suspensions? I think something is broke on the front pass. side.
Old Jan 1, 2009 | 10:25 AM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
Fordahl Motorsports is great.
John
Old Jan 1, 2009 | 10:28 AM
HUMMM 3's Avatar
HUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud of
What are the symptoms? If you like you could bring your car to my place. I have a floor jack. We could take the wheel off and take a look. If something is broken it should be fairly obvious.
Old Jan 1, 2009 | 12:26 PM
Well, when you're driving slow, and are turning the steering wheel, you can hear this moan/squeal sound. At first I thought it was the steering wheel itself or the PS pump. I looked online, some people said its because of the cold weather or there is air in the PS pump. Then last night when my sister opened the door, I hear this "ehhh" sound. I jacked up the car today, the sound went away, so I guess it was something rubbing, but the "ehhh" sound is still present.
I'll PM you
Old Jan 1, 2009 | 08:01 PM
HUMMM 3's Avatar
Sent you a PM
Old Jan 1, 2009 | 10:16 PM
detailjohn's Avatar
It sounds like you have a brake pad wear sensor possibly touching? Hard to tell without looking at it though.
John
Old Jan 2, 2009 | 12:48 AM
slidingk1's Avatar
slidingk1 is infamous around these parts
Sounds like the brake pads are gone on the inside of the front caliper. I doubt it's anything too serious. Does the car pull left or right??
Old Jan 2, 2009 | 10:44 PM
I know its not the brake pads. I heard the "eeehhhh" sound when my sister had the door open, then when we got home, I heard it again. So I pushed on the car, and I heard it. Like rocking the car, it only came from that one area..
Old Jan 3, 2009 | 04:05 PM
slidingk1's Avatar
From the way you explain it sounds like a worn out suspension bushing or one needing more grease. If it's just a "noise" and there is no additional vibration or pull left or right to affect the alignment then that's all that I can think of. Did you curb the car, hit anything on that wheel etc... recently? If not take a close look at the rubber components of your suspension.
