Other Japanese Supercars Toyota Supra, Honda NSX, Mazda RX-7 etc.
Where are the Subaru WRX STI's?
Old Mar 11, 2012 | 01:56 AM
  #61
Searcher's Avatar
Searcher has a spectacular aura aboutSearcher has a spectacular aura aboutSearcher has a spectacular aura about
STI's have much better fit and finish....You should at a minimum do the pistons to make decent power....If you build the short block completely then go have fun.....
EVO's make power easier, transmissions and diffs aren't nearly as good as the STI's though....
Both are great cars....
Old Mar 11, 2012 | 06:01 AM
  #62
wfo's Avatar
wfo
wfo is infamous around these parts
Might save your money and get thru school then come play.
Old Mar 11, 2012 | 09:11 AM
  #63
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Sorry in advance for the massive post, but there's almost no STI threads on here and I haven't noticed this one updated in a while! My STI for the record is a 2011 sedan with a Nameless muffler delete axleback, AEM intake, and Cobb AP with their stage 1 tune specifically for the AEM intake (estimated 350/360 BHP/TQ), plus some minor other mods like Enkei wheels, de-badged, better pads, and a few other things.
Originally Posted by SevenSisters
Header upgrades are touted as giving a 10-20hp increase if you go with equal length (EL) setups. The up pipe isn't really giving a gain, but you do that at the same time to ensure compatabillity with the header and turbo.
Not sure why Invidia was suggested for the header, as there are reports of fitment issues... The Tomei seems to be the most popular unit to go with, as it carries a lifetime warranty and gives good gains. FWIW, I have an Invidia divorced DP sitting here, and am waiting to pull the trigger on EL headers, and then will send the whole lot out for JetHot coating before install next spring.
Headers don't help you and only hurt you unless 1) you're pushing a rotated turbo kit and 2) you have a tuner that knows how to tune for them. The Subaru headers are more than adequate for anything up to about 400 BHP.
Originally Posted by Searcher
Teflon....sorry I have been away.....Some of these questions have already been answered.....
If you do decide to do the upgrades here is what I think is the best on the market currently.
For the header and up pipe I would go with Killer B and also get their oil pan, baffle and pick up as they are designed for track use.
Killer B is one of the pricier but better options out there. Any of the cheaper options are going to crack.
For the turbo back exhaust I would go with a company called Nameless Performance out of Washington for their complete turbo back exhaust.
I'm very familiar with Nameless. I had the first axleback for a latest-generation STI in the country after their fitment car. The only issue I've had is the powder coating came off everywhere except the tips, which they offered to fix for free, but never actually got back to me after their offer. Personally I'd go with a Cobb DP as the best in the industry due to the fact they're the only ones who use a cast iron merge collector to keep exhaust gas temps up. Their DP is smaller than some other manufacturers, but they don't seem to have problems making serious power with them!
For the suspension I still recommend sways and the coil overs of your choosing based on your budget.
Why does everyone always go right to coilovers? They're overkill and overcost for 99.99% of people. A high quality set of springs (i.e. NOT Tein S Techs) and shocks (Tokico or Tanabe) are all you really need.
Brakes are simple, upgraded pads, fluid and stainless steel brake lines if you would like.
Yes agreed. Rotors aren't really required unless you spend a lot of time on the track, then a set of slotted DBAs would be the best option.
You can do an intake, but it is mainly noise unless you get a CAI and then you might get a few horsepower.
Intakes are much more effective on the late model Subarus (including the WRX and STI) than they were on the older models. I've had my 2 STIs (2004 and 2011) sitting side by side in the driveway to look at the intakes, and the OEM system looks almost exactly the same in both, so I don't know why intakes work a lot better in the newer cars than the older ones. They definitely add a nice sound too since you can much, much, much more clearly hear the turbo spool and EWG. You definitely need to go with a cold air unless you like losing power, and the AEM is made by the OEM supplier for the SPT parts, and it's the best unit made for the car.
Get a protune on your Cobb Access Port from a reputable tuner. The stock internals are going to be good to roughly 450whp for track days as long as your tune is safe and you have VERY limited knock. Possibly invest in a turbo blanket and heat wrap headers and downpipe. I would assume you would drive around 95% of the time on a street tune at roughly 300-320whp.
Just get a Tactrix cable and skip the AP. The only benefit of the AP is the ease of use and the fact you don't need to go to a tuner. As soon as you do, I'd just go right to a Tactrix cable and laptop. Those numbers are good ones to go with for street/track use. Running anything close to 400+ whp for your street tune is going to result in a blown engine at some point unless you drive like grandma and never push it into boost.
Originally Posted by RoadRunnerSTi
Make that 450whp on a 1.00 or 1.05 correction, if you insist on a tiny correction for your altitude... An then I'll be impressed and convinced... But don't fool yourself into thinking your altitude deserves a huge 15% addition to your whp #s.
LOL.....Your grasp of reality concerning altitude is just out there.....I am very happy with my numbers considering what is done to the car and the numbers are real enough.....Turbo's can't breath or push the same amount of air at 5200+ feet of elevation that it can at sea level....
I'm probably one of the few people that has extensive experience with the same Subaru car across sea level and high altitude locations (2004 STi) and it definitely results in a 15% loss. 10% is a number nobody can argue with, and at lower parts of the rev range, I'd say 20% is more realistic. Only at the very top end where the turbo is really spooling do you get anywhere close to sea level numbers.
Originally Posted by Opusman
Ive owned an evo and have an RS4 right now, selling due to going back to school. Either gonna get another STi or go back to an evo again....STi's seem so much more complicated lol from a mechanical stand point and seem more expensive to mod. I had 400whp in my evo on my stock engine, so are you guys saying those same #'s arent really realistic without building the engine? Just wondering because all my evo friends have told me if they could go back, they'd get an STi because they are more reliable. I DD my evo for over a year and never had a single problem at that hp.
Why do people say the EVO makes power easier and cheaper? My experience is admittedly zero but how much cheaper than $250 (DP) plus tune ($350) so $600 total can you add 20% more power?
Old Mar 11, 2012 | 11:52 AM
  #64
Opusman's Avatar
Opusman is a splendid one to beholdOpusman is a splendid one to beholdOpusman is a splendid one to beholdOpusman is a splendid one to beholdOpusman is a splendid one to beholdOpusman is a splendid one to behold
Ya, Im gonna try and do more research on the sti, just lloking at the engines they seem way more complicated though lol. I really do like the way the new sti sedans looks, glad they are giving an option besides the hatch. older evos still look the best though, I know ill be hard pressed to find one thats got low miles and either lightly modded or one thats already got all my work done for me with quality stuff and at a good price.
yeah that seems pretty cheap, everytime ive looked at sti aftermarket parts though they seem more expensive than for evos. The only person in Boise id trust to tune my car(jake montgomery) charged 400 to tune evos which iswhat his specialty is anyways, but charges 700 to tune an sti, he says they are a lot more work for him and more complicated.
Also since you guys seem to have a good amount on knowledge here is an sti I found that seems to be probably the best deal, this one seems like a good deal right? Not a big fan of this body style though
http://eugene.craigslist.org/cto/2871642056.html
Old Mar 11, 2012 | 11:57 AM
  #65
Opusman's Avatar
No need to wait, my RS4 is paid off already so selling it and dropping down to one of these would leave me with about 20-25k in my pocket and ill probably do a 7-8k loan just to keep building my credit. So that leaves even more cash in my bank from the audi to over 30k. Which is more than enough to pay for the rest of my schooling at bsu
Old Mar 12, 2012 | 02:16 AM
  #66
Searcher's Avatar
Opus....The STI sedans are excellent cars....They are just a pain in the butt to make decent power above stage 2 compared to an EVO....If you aren't into the power so much then it will do wonders for you.....
Teflon....You definetly picked the most inexpensive route to fixing up the STI and it works for some....As for the suspension I agree a good strut and spring combo with the added sway bars is going to work fantastically.....
I will post up my build thread on here since it will duplicate the threads on nasioc and iwsti....
Old Mar 27, 2012 | 06:47 PM
  #67
clou's Avatar
clou is infamous around these parts
Here's my 2011
Stage 1 with AEM CAI and Nameless 3.5" axleback. Also has some minor suspension upgrades.
She will be missed
Old Mar 27, 2012 | 08:19 PM
  #68
Opusman's Avatar
^^^are you putting her up for sale? I like the color on that one it looks good
Old Mar 27, 2012 | 08:59 PM
  #69
CRobbins's Avatar
CRobbins is infamous around these parts
It's already for sale!?
That's my favorite color across all model year WRX/STI
Old Mar 28, 2012 | 02:09 AM
  #70
clou's Avatar
My brother is going to take it over as I'm leaving the country come September. Gives me an excuse to shop around for an M though
Oct 2, 2015 02:23 PM
fredz
Sep 27, 2015 05:54 PM
fredz
Sep 23, 2015 04:20 PM
changster
Sep 18, 2015 07:31 AM
