Need advice on spacers
Old Apr 18, 2011 | 11:48 PM
RussianS4's Avatar
RussianS4 is infamous around these partsRussianS4 is infamous around these parts
I am looking to install spacers . no more than 7mm
any advice on brand ? best place to buy ?
thank u in advance !
Old Apr 19, 2011 | 09:24 AM
dallascajun's Avatar
dallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant future
When I had my P2S, I had 7mm on rear, 5mm on front. I had the 7mms as leftovers from a previous 911 (H&R), but bought the RSS spacers from Suncoast (Sponsor link on the right).
Old Apr 20, 2011 | 12:58 AM
RussianS4's Avatar
Hey wjohnson36
Is 5mm / 7mm batter st up? would you do all 5mm if you would not have leftovers from previous 911 ?
oleg
Old Apr 20, 2011 | 06:02 AM
I prefer a more aggressive stance. My 911 had 7mm front, 14mm rear. The Panamera doesn't have enough of a gap for the 14mm (the wheel would stick out), so I used the 7mm in the rear. Since Porsche doesn't have an option for Spacers in the front (see online configurator), I chose to only put 5mm there. To me, the front still needed something, and the 5mm did the trick.
Since the difference between 5mm and 7mm is so small, if I were doing it from scratch I'd just get 5mm all around as to avoid issues with getting the different bolt sizes mixed up.
Old Apr 27, 2011 | 10:47 PM
RussianS4's Avatar
wjohnson36 .. thank you for your help
if i go with 5mm all around do i need new bolts ?
Old Apr 28, 2011 | 04:25 PM
5mm Spacers don't require new bolts (7mm does).
007 Vantage
Sep 22, 2015 02:28 PM
saiko88
Sep 11, 2015 02:17 PM
shinjuku
Sep 5, 2015 02:02 AM
