PCM usage question - next track
Old Jun 11, 2011 | 10:41 AM
chu996c4's Avatar
chu996c4 is infamous around these parts
I have a quick question on the "next track" arrow button.
I have programmed it into the multifunction button on the steering wheel so that I can toggle through the next track on ipod or CD without going back to the PCM screen or using the button.
Is there a way in the TUNER section so that it goes to the "next programmed preset"? It is retarded that the next button when you have it programmed literally goes to the next station it finds. most cars have the feature where you can set the "next arrow" to tune to the next preset.
I have read through almost the entire PCM manual and can't find anything.
Any help is appreciated.
Regards,
Old Jun 13, 2011 | 01:08 PM
ejv's Avatar
ejv
ejv is infamous around these parts
Hi,
Yes I had this same problem. On your display slelect vehicle, then settings, then display, then audio. You will have two choices, station list which list stations available in your area (factory setting) or Preset list, your programed stations. Now you should be able to scroll through presets.
Please note presets does not work for SAT. It defaults to station list.
Hope this helps!
Old Jun 13, 2011 | 01:35 PM
chu996c4's Avatar
Thanks!!!
Jul 29, 2019 11:13 AM
pilotscottb
Sep 1, 2015 10:29 PM
mjacobellis
Aug 20, 2015 09:13 AM
