Going Above 100MPH, Low Tire Pressure
Old May 23, 2012 | 08:55 PM
toughluck's Avatar
toughluck is infamous around these parts
ARGH! It is annoying to receive a low tire pressure warning when I go above 100MPH... but at the same time I love how great the car is, and how it reminds me I could be driving above 100MPH more safely if the tires are properly inflated. Got to fill up my tires the next time I stop.
Old May 24, 2012 | 06:04 AM
MI55LE's Avatar
MI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to behold
(weren't you "stopped" when you posted this..?)
(I don't condone driving over 100 mph, but..) I carry a 12v tire pump in the trunk, as I've got (very) slow leaks in 2 of my tires and I drive my car on extended fun trips
Old May 24, 2012 | 07:08 AM
umwolverine's Avatar
umwolverine is infamous around these partsumwolverine is infamous around these parts
You need to check those leaks. You've either got some punctures, or the tire wasn't mounted properly.
Old May 24, 2012 | 08:25 AM
kip's Avatar
kip
kip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to behold
Check the pressures asap!!!
Old May 24, 2012 | 10:01 AM
djantlive's Avatar
it could be just low on air or a leak
leaks often happen at the valve stem. some can be repaired without taking the tire off. if you find yourself needing to top off air every couple of weeks, you should have the tire checked by a good tire shop. they often will do it for free actually. just dont go to those big chains that tend to upsell you.
Old May 24, 2012 | 09:07 PM
toughluck's Avatar
Yes, I was stopped. A slow leak may also be because of a bent rim (don't ask how I know...)
Old May 25, 2012 | 10:58 AM
MI55LE's Avatar
tires were removed and checked for leaks - none
wheels were checked for bends (OEM but chromed) - none
wheels were cleaned before tires remounted - no leaks since (but I still carry the 12v puffer in the trunk)
Old May 25, 2012 | 02:45 PM
Sounds like they just didn't clean/seal the beads properly before mounting - problem solved. Glad that's all it was.
Old May 25, 2012 | 08:00 PM
MIA997TTBeast's Avatar
MIA997TTBeast is infamous around these partsMIA997TTBeast is infamous around these parts
Speaking of tire pressure... I have 22's and the car wants me to fill them up to at least 42psi F and 39 R... Is this high? When you go to Fill Info, if the tires are at 40 F and 39 R it tells me that I'm -4 in the fronts and 0 in the back (which means the back are fine but the fronts need 4 more psi)
Should I have them always at 44 or should I lower them to like 40 and tell the system to learn this is what I goddamn want...
What should I do?
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
Gewgaw
Aug 19, 2015 11:52 PM
