Failed front air suspension strut - has it happened to you?
Old Sep 2, 2013 | 08:08 AM
phil612's Avatar
phil612 is infamous around these parts
Hi,
The left front air suspension strut on my PTT appears to have sprung a leak, left parked it slowly collapses so that overnight that corner of the car is sitting on the suspension stop. My independent says they've "seen several of these (on Panamera) and also Bentley as it's the same supplier"... I was a bit surprised to be honest, the car only has 22,000 km on the clock.
Anyone else had this issue?
Old Sep 16, 2013 | 10:26 AM
pgeoph's Avatar
pgeoph is infamous around these parts
I had the same issue with the front right after the dealer disassembled it to replace the upper control arm. Ended up replacing both fronts and the pump before it was over. There is an issue with the pump housings cracking. Still leaks but even after 2 weeks without being driven it has sagged only about 1/2".
Old Sep 16, 2013 | 10:55 PM
phil612's Avatar
Well mine is going in today to have the left strut replaced (and left+right upper wishbones.. creaking bushes issue)... Then they're going to measure it up, leave it overnight to see if there is any additional sag, if so it'll be on to the reservoir tank and pump I guess...
If I could spec the Turbo or GTS without air springs, I would.
Old Sep 19, 2013 | 06:22 AM
phil612's Avatar
So by way of an update.. front upper wishbones replaced both sides (bushings had delaminated and were causing a creak over speed humps and hard braking), left front air spring replaced (but same shock), car no longer sags or drops parked overnight. Hopefully fully resolved.
Old Sep 21, 2013 | 07:55 AM
dyc1077's Avatar
dyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud of
Did the sound go away? Cost to replace the upper wishbone?
Old Sep 21, 2013 | 08:17 AM
phil612's Avatar
Yes, sound completely gone, done at an independent workshop here in Singapore for S$1,320 (US$1,000). When they did the alignment work the computer indicated some slight geometry shift under compression which is likely due to the lower bushes being soft (these will likely be the next to need replacing).
Old Sep 21, 2013 | 08:53 PM
TheBeav's Avatar
TheBeav is infamous around these parts
Phil612 - I used to live in Singapore. Your COE must have been extraordinary on a panny. In america my PTT new wasnt much more than a Honda jazz/fit in Singapore.
Old Aug 10, 2017 | 05:54 PM
mwvh's Avatar
mwvh is infamous around these parts
I just had to replace the right air strut on my 2011 PTT with 40K miles. I can't believe that those struts are not made to last longer.
Was quoted over 3,000 USD to do the one by my local Denver PC.
Anyone else had a similar experience?
Old Aug 10, 2017 | 06:39 PM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
How much of that is labor? Sounds crazy.
Old Aug 10, 2017 | 08:59 PM
mwvh's Avatar
I'm not sure, as haven't received the breakdown yet. They claim it's a full day's work, so I assume it's more than half the cost.
Old Aug 11, 2017 | 10:08 PM
hollynitro's Avatar
hollynitro is infamous around these parts
when the air strut is leaking , better to replace with new one . because , the compressor will work over the time to supply the air when it's leaking .. i think no other way to fix it . and use the original from porsche .. don't try after market / rebuild will waste your time & money .
Old Aug 12, 2017 | 02:33 PM
orangeokie's Avatar
orangeokie is infamous around these parts
Phil, what MY is your car?
Old Aug 13, 2017 | 06:29 AM
riden's Avatar
Not had the problem yet, but I typically use the comfort tire pressure specified in the manual. That might prolong the strut lifetime. When the time comes for replacement, I'll just replace rebuild the front end too.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
