Adding OEM Aftermarket
Old Feb 9, 2014 | 08:22 AM
Darticle's Avatar
Darticle is infamous around these parts
I can't seem to find an inventory '14 GTS that is specced as I would my own order. Although I can be patient and wait for an allocation, I was wondering if the following items can be installed (as if OEM) after market:
1. Lane departure warning
2. Rear window shade
3. Soft-close doors
Any insight would be appreciated!
Old Feb 9, 2014 | 10:36 AM
mrrippey's Avatar
mrrippey is infamous around these parts
I'd have to say not likely. Good luck in finding your car. I'm in the same boat.
Rippey
Old Feb 9, 2014 | 02:14 PM
supercup's Avatar
supercup is infamous around these parts
Lane departure warning cannot be put on after. Rear sunshade would require wire harness, button on dash and the shade - cost versus an order would not be too appealing. Soft close doors probably not, and if you found a dealer that would you would not like the economics of that either.
Be patient, get an order allocation and get exactly what you want!
Lane change assist is a must on the Panny.
Old Feb 9, 2014 | 02:45 PM
Darticle's Avatar
Thanks for the replies! I will be patient and order it as desired...
Old Feb 9, 2014 | 07:53 PM
dhh's Avatar
dhh
dhh has a spectacular aura aboutdhh has a spectacular aura about
lane departure warning is useless - I love the blind spot warning - but the LDW beeps all the time if you don't use your turn signal - I would not worry about that option - I leave mine off all the time.
Old Feb 10, 2014 | 08:12 AM
toughluck's Avatar
toughluck is infamous around these parts
Yeah, I really wanted rear sunshades and investigated this however does not appear cost-feasible, as new rear trim needs to be purchased.
  • Alternatives: Tint and Britax add-ons from Amazon look really clean. I did check out Sonniboy in Germany and they said they would look into it.
Lane-Departure: Again, a lot of sensors (I think under the body work too).
  • Alternatives: Suncoast has convex mirrors that can help, but I understand the feeling when you drive a car with lane-department and get back into a car without it.
audipwr1
Sep 25, 2021 01:31 PM
pwdrhound
Aug 23, 2015 07:36 PM
oddjob142
Aug 19, 2015 12:27 PM
HolmaN
Aug 18, 2015 01:35 PM
