Renntech Digital Lowering Module for Panamera
Old Apr 14, 2014 | 07:32 AM
Mike@Renntech's Avatar
Mike@Renntech is infamous around these parts
The NEW Porsche V3.5 Digital Lowering Module (DLM) is designed to work with the latest model air suspensions.These updated air suspensions utilize newly developed factory control units and are found in the following vehicles:
2010-up Porsche Panamera (970)
  • Panamera S Hybrid
  • Panamera GTS
  • Panamera Turbo
  • Panamera Turbo S
As with the V3 module, it requires no splicing or soldering.The RENNtech harness utilizes the factory pins as to allow a completely reversible installation.
All RENNtech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
RENNtech V3.5 DLM Module Specifications:
  • Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
  • Adjustment increments: 1mm
  • Maximum Lowering: Limited only by vehicle
  • Adjustment Methods: PC or Android (Tablet)
  • Size: 53mm x 73mm x 24mm
  • Weight: 1.2oz
Please contact me with any questions or to place an order.
Optional Samsung Tablet
ID:	359534   Click image for larger version
Old May 2, 2014 | 09:00 AM
5% off and FREE GROUND SHIPPING this month!!! (lower 48 states only for free shipping)
Old May 3, 2014 | 07:23 AM
cvprez's Avatar
cvprez is infamous around these parts
how much is it??
Old May 5, 2014 | 07:10 AM
List price is $1395.00 and the optional tablet is $350
Originally Posted by cvprez
how much is it??
Old May 8, 2014 | 06:14 AM
b911s's Avatar
b911s is infamous around these parts
Wanted to give a shout out to Mike as I ordered the lowering module from him last week for my 14 GTS. Installation of the actual module was pretty straight forward with the swapping out of the 4 wires from the Porsche harness to the Renntech. The biggest PITA was getting to the control module located in the left rear of the trunk. Once installed, the Renntech software is very simple to use and very adjustable. Make your adjustments, send the file to the module and bingo, your car is lower. The cool thing too about the system is that it raises the car back to stock height once you reach 30 MPH to avoid any unnecessary tire wear and no need for realignment. You can adjust this setting as well and pick at what MPH the car will return to stock height or eliminate the feature all together.
Would recommend this product for anyone wanting to lower their air suspension equipped Panamera. After my research the Renntech unit offered the best value, ease of use, features and range of adjust-ability. Thanks Mike!
Bruce
Old May 8, 2014 | 07:22 AM
Thank's Bruce I am glad to hear the install went well and you're enjoying the product.
Bruce
Old May 8, 2014 | 01:30 PM
CMLXX4S's Avatar
CMLXX4S is infamous around these parts
Do you guys have any dealers in North Carolina - Raleigh/Durham/Charlotte? I'd like to purchase and get installed... I'm somewhat mechanically inclined, but I'd rather leave mods to the pros.
Old May 8, 2014 | 01:40 PM
PM Sent
Old May 9, 2014 | 01:39 AM
rufus1972's Avatar
rufus1972 has a spectacular aura aboutrufus1972 has a spectacular aura about
Hello...
You don't have picture with the maximum lowering?
Regards
Pascal
Old May 9, 2014 | 07:19 AM
I do not have a picture of max lowering but you should be about 2's. If you hit the bump stops it will throw error codes.
sdg1871
Jul 28, 2025 09:51 AM
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
dgreen78
Feb 29, 2016 11:28 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
