Panamera Compressor / Valve Block Problem
Old Mar 14, 2016 | 10:07 AM
hollynitro's Avatar
hollynitro is infamous around these parts
Smile Panamera Compressor / Valve Block Problem
Hi guys,
can you share with me , anyone here got problem with your Compressor / Valve Block ? And, How's the symptoms ?
Old Mar 15, 2016 | 02:19 PM
iammulva's Avatar
iammulva has a spectacular aura aboutiammulva has a spectacular aura aboutiammulva has a spectacular aura about
Not an expert, by any means, but had problems. Compressor may run continuously or frequently. The system monitors pressure and the compressor will fire when pressure goes below a certain level. I think it is regulated per corner. If you suspect a problem, you can hang out near your trunk for a while and listen for the compressor to kick on. Alternatively, you can eyeball (or measure) to compare gaps between two front (or two rear) tires and fender lip. This may help you determine whether you actually have a problem, but obviously is not a scientific approach.
One thing's for sure, if the valve block or an airbag fails, you will know it because your car will all of a sudden have a slammed look. If you suspect you have suspension issues, I suggest that you identify a tow company now that has experience towing extremely low cars. That way, if it does fail, you'll have someone who can tow it without tearing up the bumpers. If you're covered under warranty, get a Porsche roadside assistance approved tow company.
All in all, it's a bit of a pain when the front goes down.
Old Mar 26, 2016 | 10:23 PM
hollynitro's Avatar
thanks for your reply ,
my car slammed only in the front suspension. and , i hear the compressor near the trunk like working too much . already checked with another workshop (not Porsche Dealer) , but he has a porsche computer to check . in Indonesia , Porsche Spare Parts are extremely expensive.
Old Sep 8, 2024 | 12:10 AM
Iticip's Avatar
Iticip is infamous around these parts
I am having the same problem, front suspension on the floor all of a sudden.
Did you resolve the issue?
panamera87
Feb 20, 2023 12:45 PM
panamera_lou
Jul 30, 2022 07:58 PM
Mhl
Jul 27, 2022 06:47 PM
rsbIII
May 31, 2019 12:04 PM
hollynitro
Jan 29, 2016 11:29 AM
