Turbo 2 Stage Rear Wing
Old Aug 15, 2016 | 04:59 AM
amgpan's Avatar
amgpan is infamous around these parts
Not sure if anyone has noticed, but i only noticed this on the weekend just past.
ONLY if the SPORT PLUS button is pressed, the rear wing will come out, and extend. (or if its manually extended with the button)
But after about 100 kph (60 mph), the rear wing tilts, and stays tilted until speed drops below about 70kph (45mph)
I only noticed this on the weekend. When going over 100kph, and say sport plus is activated, look in your rear view mirror, and then just press the "SPORT" button and the wing will tilt back down to normal, then press the sport plus button, and it will tilt up.
Very cool. Never noticed it before.
Am i the only one?
Old Aug 15, 2016 | 05:50 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
The wings extends even more after 130km/h to create more downforce
Old Aug 15, 2016 | 07:40 AM
amgpan's Avatar
Yep. but it appears only extends when in sport plus mode. Correct?
Or will it extent in any mode over 130?
Sport plus will extend earlier (100) ?
Old Aug 15, 2016 | 08:52 AM
amgpan's Avatar
Is there a way to manually extend the wing?
Old Aug 15, 2016 | 09:59 AM
negb's Avatar
negb is infamous around these parts
by this button
Old Aug 15, 2016 | 12:21 PM
dudecs's Avatar
dudecs is a jewel in the roughdudecs is a jewel in the roughdudecs is a jewel in the rough
For all models and mode, the wing will extend automatically. There are two positions for the spoiler when deployed. From the user's manual for previous models...
“Sport Plus” mode deactivated
The rear spoiler extends automatically:
– to position A at approx. 55 mph (90 km/h).
– to position B at approx. 130 mph (205 km/h).
The rear spoiler retracts automatically:
– from position B to position A at approx. 110 mph (180 km/h).
– from position A to the end position at approx. 40 mph (60 km/h).
“Sport Plus” mode activated
The rear spoiler extends straight to position B at approx. 55 mph (90 km/h).
The rear spoiler retracts from position B straight to the end position at approx. 40 mph (60 km/h).
Old Aug 18, 2016 | 08:08 AM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
If you hadn't posted this thread I never would have noticed the Position B for the spoiler. I put it in sport plus and hit the throttle, and sure enough it popped forward to position B.
Old Aug 18, 2016 | 08:16 AM
dudecs's Avatar
Yes. Driving on public roads in normal or sport, not likely that one will exceed the speed for position B to be activated... without getting thrown in jail.
Old Aug 18, 2016 | 08:57 AM
amgpan's Avatar
See i am some use around here even for 1 person.
Is there a way to extend to position B manually?
Old Aug 18, 2016 | 09:42 AM
dudecs's Avatar
Manual activation only extends to position A. In sport plus mode, it will automatically extend directly to position B above 55mph.
Old Aug 18, 2016 | 09:28 PM
amgpan's Avatar
Would love to be able to have it in extended mode
Old May 16, 2018 | 10:27 PM
atwong1's Avatar
Emerging Sponsor
5 Year Member
atwong1 is infamous around these parts
This is so cool. But you know what's cooler?
Old May 17, 2018 | 09:36 AM
negb's Avatar
I can't believe that there were questions after I posted answer with image and red arrow pointing what to button to push to extend it to any position !
https://www.6speedonline.com/forums/...ml#post4549878
Old May 20, 2018 | 12:36 AM
atwong1's Avatar
Emerging Sponsor
5 Year Member
Adding a stage is cooler. However, reprogramming all 3 stages to map to lower speeds, priceless...
Presenting to you my latest experiment...
Old May 20, 2018 | 08:56 AM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
On 970 GTS models, choosing sport plus lowers the car. Choosing the maximum damping on the shocks does the same thing. Only reason I noticed was when switching from maximum damping to comfort setting at at stop light. The car raised itself. So nice to get the lower level without the sport plus and all the stuff that comes with that.
