key not detected message
Old Nov 12, 2016 | 10:27 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Got a "key not detected" message once or twice over the last few months. Took key out of pocket and then it started.
I think I put a new battery in the key fob when I got the car a few months ago. I don t use the car everyday if that matters?
Any ideas ? Future problem starting out? or normal? Thanks
Old Nov 12, 2016 | 10:41 AM
cvprez's Avatar
cvprez is infamous around these parts
Change the battery - that should correct issue.
Old Nov 12, 2016 | 11:06 AM
cerbomark's Avatar
Thanks, will do.
Old Nov 12, 2016 | 11:13 AM
cerbomark's Avatar
OK, done. FYI/ its a CR2032 battery. You slide the valet key out about 3/4 of the way and then just pry up to access battery.
Old Nov 19, 2016 | 12:19 PM
enduro963's Avatar
enduro963 is infamous around these parts
I got the same error message, fixed it same way. No more error message! 🎉
Old Nov 20, 2016 | 07:12 AM
cerbomark's Avatar
I can report no more message since I changed the battery... Thanks!
