throttle response slow in normal mode?
Old Jan 8, 2018 | 07:19 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
On my Panamera I have slow throttle response in normal mode as it feels like i have to give it a little bit more gas just to get it going (when turning from a slow speed/rpm or when accelerating from a stoplight/sign) is this normal?
Also When I put it in sports mode I have to go light on the accelerator when accelerating from a stop otherwise i will get some jerkyness. If I am doing city driving in sports mode with constant low rpm and breaking/accerlating then its a jerky experience.
Is this the same for everyone or do I need to do a fix/upgrade on my vehicle?
Old Jan 9, 2018 | 07:56 AM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Which model to you have? If it's NA, it may just be the drive-by-wire that you're feeling. There are aftermarket products (i.e.. Sprint power booster) that can be installed to address this issue.
If you have a turbo, you may simply be feeling the effects of turbo lag - this was my issue and I flashed my ECU to get it resolved. Now in comfort mode it drives similarly to when Sport mode was engaged stock, and now Sport mode is even more immediate. I think you can find a solution out there to address your concerns. Good luck!
Old Jan 9, 2018 | 08:21 AM
newporsche's Avatar
5 Year Member
i have the panamera S so yes the NA...i heard of sprintbooster, is it safe to use?
Old Jan 9, 2018 | 08:42 AM
skiracer13's Avatar
5 Year Member
I had a NA 911 prior to my PTT and I experienced the same issue. I installed the Sprint power booster and it absolutely worked and solved the delay issue - throttle response was greatly improved. I had this device installed for 8 years or so and never had a single issue w/ it. Worth checking to see if they make one for the Panny IMO.
Old Jan 9, 2018 | 10:03 PM
Max Varga's Avatar
5 Year Member
Max Varga has a spectacular aura aboutMax Varga has a spectacular aura aboutMax Varga has a spectacular aura about
I have 2015 S e-hybrid. I also hated throttle response and drove it almost always in sport mode which can be jerky in town. Gearbox software was upgraded twice but no luck.
I had minor accident with car - it was at dealer with power disconnected for two weeks. After that during repair process they wiped all software and then reinstalled it.
After this I haven't used sport mode as car now drives very smooth and responds as it should. It is definitely not placebo.
Old Jan 9, 2018 | 10:38 PM
newporsche's Avatar
5 Year Member
interesting, how would i go about reloading the software? i did the throttle reset proceedure and i think that also helped but i dont know if its all in my mind or if it actually helped
Old Jan 9, 2018 | 10:43 PM
Max Varga's Avatar
5 Year Member
I forgot one more thing - prior to delivery software was updated at the dealer. At first service the mechanic told me that software update was incomplete first time and that this time he succeded. Apperently not. But now all is ok. Different car to drive.
Old Jan 10, 2018 | 06:03 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
well if you feel better driving it then it worked. as long as you are happy.
akn
Jun 4, 2011 11:07 PM
997TurboTom
Apr 28, 2008 11:23 AM
LSM
Sep 21, 2006 01:45 PM
