DIY: Panamera turbo rear differential fluid change
Old Jun 24, 2018 | 09:00 PM
ciaka's Avatar
Post DIY: Panamera turbo rear differential fluid change
Replacing fluid on rear differential for 4 wheel drive panamera turbo. This applies to 4-wheel versions of Panamera. Not sure if fluid is same on other versions, but assume should be ok (but its up to you to verify).
Follow each picture in order from start to end.
Read entire set before you start. This gives you a good idea of what to expect, without any surprises (oh, I don't have this tool, etc).
This DIY uses Mobil Delvac 1 full synthetic gear oil 75-W90, which I was able to reference to the factory fluid Porsche uses - Shell TF0951.
Replacement schedule is every 120,000 miles or 12 years. I would definitely not wait that long to do this. After 60,000 miles the fluid is not even translucent, has a very characteristic metallic smell to it. Similar numbers were stated for Cayenne turbo vehicles, and folks were all changing these fluids after 60k miles. I would do so here as well.
If you see anything that you know is not correct, please chime in so it can be corrected. Thanks and hope it helps.
Fluid details - Rear differential:
  • Service Manual - factory fill: #18 on page 527 of Tequipment manual (Panamera 2010-Today) - Fill Qty: 1.15L for my PTT
    • Part No. 000 043 205 30
    • 75 W 90 GL-5 rated gear oil with carbon modifiers
    • Fill until it drips out fill hole, then close
  • What I used:
    • Mobil Delvac 1 75 W 90 gear oil (same as front final drive since has modifiers in it, and meets GL-5 rating as well)
Fluid details - Front final drive:
  • Service Manual - factory fill: Shell TF0951 - Fill Qty: 0.425L
    • Number 9 on page 518 of Tequipment manual (Panamera 2010-Today)
    • Part number 000 043 301 18
      • I found direct cross reference to Mobil Delvac 1 synthetic gear oil 75W-90 (that is what I used in my front final drive fluid change)
      • Fill until spills out of fill hole, then close
  • What I used
    • Mobil Delvac 1 synthetic gear oil 75W-90 (due to direct cross reference with Shell TF0951)
  • FSM fluid quantities in post #8 of this thread.
ID:	527903   Click image for larger version
ID:	527904   Click image for larger version
ID:	527905   Click image for larger version
ID:	527906   Click image for larger version
ID:	527908   Click image for larger version
ID:	527909   Click image for larger version
ID:	527910   Click image for larger version
ID:	527911   Click image for larger version
Old Jun 24, 2018 | 09:01 PM
ciaka's Avatar
Part 2 of DIY...
Again, if you know for a fact something is inaccurate please bring it up so we can correct asap.
Thank you.
ID:	527913   Click image for larger version
Old Jun 27, 2018 | 09:03 AM
Victory007's Avatar
Victory007 is infamous around these parts
Awesome job - {adds to the to-do list}
Thanks!
Old Jun 27, 2018 | 10:15 AM
negb's Avatar
negb is infamous around these parts
That's what I found after rear differential fluid change at Porsche dealer.. And I was blamed that I damaged differential shield by hitting something with bottom of my car..what a pish; and two bolts were cut of like with grinder and no more damages or even scratches anywhere else .
Name:	97035083001 Air Baffle Plate.jpg
Old Jun 27, 2018 | 10:22 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
Wow!
Old Jun 28, 2018 | 10:12 AM
ciaka's Avatar
Old Jul 3, 2018 | 11:45 PM
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
How's about front differential for 4WD? I always wonder about the front differential.
Thank You
Old Jul 4, 2018 | 06:22 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
Here's some capacity info from service manual which might be useful.
Old Jul 4, 2018 | 08:14 AM
ciaka's Avatar
I was unable to access the drain plug from under car for front final drive. Did not have time so did not do yet. When I get a chance I will do the front as well ans will put up a DIY fir it too. Already have half the pics.
I wanted advice on how to reach the plug (trying from under car, there is a large axle carrier brace in the way which I dont think should be coming out fkr the change).
I think the plug can be reached from the side after tire and wheel lining is removed. Will try soon. If anyone who has done it can chime in, would be awesome.
Thank You
Old Jul 4, 2018 | 09:26 AM
HP41's Avatar
You may beat me to it. I plan on doing both front and rear in about 3 weeks. I do have access to a 2-post lift which makes access to undersides much easier.
I'll post any learnings from when I replace the fluid. (no plan for any analysis on the diff gear oil)
Old Jul 4, 2018 | 09:50 AM
DogWood's Avatar
5 Year Member
the race is on! :-)
keep up the good work guys, my car will be hitting the 60k mark late this year/early next and I will be wanting to do this as well....
Old Jul 4, 2018 | 12:53 PM
That's awesome, guys !!! We all should own you Chuck and Ciaka
a bottle of wine for great work, LOL ... Yes, FJ Porsche Fremont charges $1K for Transmission and Diff Front and rear. When you head to SF, please give the Porsche SF community a call, we treat you for lunch ...
Thank You.
Old Jul 4, 2018 | 02:33 PM
ciaka's Avatar
Np dougcayenne. However I would prefer if you 'owe' me as opposed to 'own' me. lol
Glad to hear you find this useful. I know how intimidating it feels to have a nice car and not wanting to tackle issues in case something else breaks. My first car was Cayenne turbo, and I overcame this threshold with that car. Since, I have done many things on my own on both the Cayenne and the Panamera, saving tens of thousands, literally. Doing myself, I know nothing will be ignored or accidentally broken and hidden.
I used to live in Milpitas for several years while I worked at one of the tech companies in Silicon Valley.
Who knows, maybe we meet up sometime.
Thank You.
Old Jul 4, 2018 | 02:35 PM
ciaka's Avatar
If you end up doing this first, try to see what the access is to drain hole for front final drive from passenger side wheel well. Have to remove wheel and lining for this.
I tried to see from under the car but the axle carrier brace is covering the area. I can see the inspection hole, but did not get to the drain hole. I was actually going to try today, but wife discovered other things to do around house, so guess what - happy wife, happy life.
I will still try next opportunity (maybe this coming weekend).
I am putting a two post lift as a nice to have gift for myself next opportunity. Started prepping wife for it. They are not too cost prohibitive. Saw some 9000lbs lift, for 1500. Install very simple, 4 bolts into concrete in garage. Then, you can pretty much do anything in there.
Old Jul 4, 2018 | 02:56 PM
Ciaka,
Milpitas is so expensive now as the whole bay area. Traffic is massive during the commuting time ... Take me 1 hr to get back from FJ Porche to Zanker, 4.8 miles in the morning. You know FJ Porsche Fremont …
Cayenne is easy to work, I like my truck 2014 CayenneS... PAN is better … That’s nice to have a lift in the garage, great deal for 1.5K. 1 major tune-up at Porsche is paid for the lift …
Good work for posting DIY. PM when you are in town for Biz, we find time to get together for lunch. LOL ...
