PDCC reservoir replacement
Old Jun 27, 2018 | 06:20 PM
dudecs's Avatar
dudecs is a jewel in the roughdudecs is a jewel in the roughdudecs is a jewel in the rough
Originally Posted by negb
yes, that's correct, PDCC/Power Steering Oil Tank - 110.14eur - p/n 97035907101.
Somehow at first place I've got p/n 95531401520 (as per 'dudecs' post - for some reason was called ''PDCC Reservoir'' - 47.88eur which of course was wrong part, even using VIN number..... still laying on the shelf, f*** !
They didn't do a proper VIN lookup to verify that your vehicle had PDCC??? The exploded parts diagram should have shown the two different types of reservoir and application for each in the description. The US parts catalogs shows that info, albeit not clearly obvious. Discrepancies between the European catalog?
Old Oct 15, 2019 | 03:35 PM
Robert Dunn's Avatar
Robert Dunn is infamous around these parts
I have a Cayenne 2010 Base model and can not find a second reservoir. Does the base model have PDCC and power steering or just power steering? i think i just have the translucent reservoir, I also replace it every 6 years?
Old Oct 15, 2019 | 03:40 PM
dudecs's Avatar
There is only one reservoir for "Power Steering" only or "Power Steering and PDCC". "Power Steering" only has a translucent reservoir. "Power Steering and PDCC" has a black reservoir. Look up your VIN to see the options on your Cayenne.
Old Nov 5, 2019 | 10:13 AM
Kamrooz Karimi's Avatar
5 Year Member
Kamrooz Karimi is infamous around these parts
Need Help
First thanks again for this very helpful post
I had replace my Steering wheel with PDCC radiator on PTT but after all I have problem with bleeding air
there is any method or technic need to air out of the system
Do you think my reservoir need replace ?
🙏🏻 Thanks
Old Nov 5, 2019 | 05:50 PM
5 Year Member
Help
Hello 👋 all
I just replace my power steering wheel radiator on ptt with Pdcc system but air on my steering line and car make noise and kick when turning
I tried many different way to bleed air but is not work
do you guys think I need to replace my reservoir or have any technic or method to air out need special tool ?!
Thanks again 🙏🏻
Old Nov 6, 2019 | 12:11 PM
tastefulmod's Avatar
tastefulmod is infamous around these parts
Does the non PDCC need replacing as well?
Old Nov 6, 2019 | 02:09 PM
dudecs's Avatar
No for non-PDCC. For US spec Porsche vehicles, you can download the maintenance schedule for your year and model. Per the 970 maintenance schedule, reservoir only needs to be replaced if is optioned with PDCC.
Old Nov 6, 2019 | 02:13 PM
dudecs's Avatar
Originally Posted by Kamrooz Karimi
Hello 👋 all
Thanks again 🙏🏻
WM 4890IN TEST AND ASSEMBLY WORK ON POWER STEERING (EXCEPT
PANAMERA EXECUTIVE, PANAMERA GTS, PANAMERA TURBO S, PANAMERA 4
EXECUTIVE, PANAMERA PLATINUM ED., PANAMERA 4 PLATINUM ED.) > BLEEDING > BLEEDING THE STEERING SYSTEM
Information
The steering system and PDCC have a shared reservoir. If repairs are carried out on one system, it is necessary to bleed both systems. [img]file:///C:\Users\Kar\AppData\Local\Temp\msohtmlclip1\01\cl ip_image001.png[/img]
The reservoir must always be replaced if individual or multiple components, such as the tandem pump, PDCC valve blocks (FA/RA), PDCC anti-roll bars (FA/RA) are replaced.
If system faults still occur after replacing a component (another component is defective), the reservoir does not have to be replaced again.
1. After installation is complete, raise the vehicle so that the wheels are no longer touching the
ground.
2. Open engine cover and reservoir.
3. Fill reservoir up to the MAX marking, until the level no longer drops.
4. Then turn the steering to the left and to the right. Hold the steering on full lock for approx. 30
seconds on each side until the level no longer drops. Continually check the fluid level and fill to the MAX marking again if necessary.
5. Lower the vehicle onto its wheels. Briefly start the engine, let it run for approx. 1 second and
add Pentosin again. This procedure causes the fluid level in the reservoir to fall rapidly, so constantly add more Pentosin CHF 202. The reservoir must not be sucked dry.
6. If the fluid level in the reservoir does not fall any further when the engine is briefly turned over,
start the engine and let it run at idling speed.
7. Turn steering on full lock several times to left and right at idling speed and observe the fluid
level during this procedure (second worker required). If it continues to fall, add fluid until the
level in the reservoir remains constant and no more air bubbles circulate in the reservoir when the steering wheel is turned.
8. Switch engine off and set the correct fluid level. This must be between the MIN and MAX
markings.
When the correct level has been reached, no air bubbles must be circulating in the reservoir and the fluid level must no longer drop.
Old Nov 7, 2019 | 08:23 AM
5 Year Member
Thanks Thanks Thanks
Information
ground.
markings.
Wow that is so awesome
just one think the first part said ( raise the vehicle so that the wheels are no longer touching the
ground) that means all wheel or just front wheel ?
Old Nov 7, 2019 | 04:51 PM
ciaka's Avatar
Typical way to remove air from power steering is fill up system more than max, then while car starter keep moving to max left, then max right, and keep going, then check power steering fluid level. Eventually it wont keep going down.
Old Nov 29, 2019 | 07:47 PM
NormalFellow's Avatar
NormalFellow is infamous around these parts
Old Nov 29, 2019 | 08:45 PM
5 Year Member
Originally Posted by NormalFellow
Thanks for reply
I try all methods for bleeding air but not work
and I schedule for Porsche dealer next week to figure out
also I fund this video for PDCC system adjusted and setup by Porsche tools and ask the owner he said they do by computer
how did you use this tools ?
Old Dec 7, 2020 | 05:04 PM
andrewyansauko's Avatar
Registered PM
andrewyansauko is infamous around these parts
Just bought a 2015 Panamera base V6. Does anyone know the power steering fluid capacity of the system including the resevoir? I am doing an "incremental" fluid change: drain the resevoir, fill with new CHF202, drive a week, repeat, repeat. By the 6-7 time, there should be less than 15% old fluid remaining. Would like to know the total capacity to see if that will do it or if I have to repeat a few more times. Thanks.
Old May 21, 2021 | 10:22 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Yay, one less thing to worry about! (Thank you)!
VIPNiSS
Cayenne 955/957
Feb 13, 2021 08:22 AM
crowland
Cayenne 955/957
Feb 23, 2012 08:03 AM
Shay2n10
Mar 10, 2009 06:36 AM
Cpa4S
Cayenne 955/957
Jun 13, 2008 02:52 PM
alex911s
Cayenne 955/957
Aug 31, 2007 09:31 PM
