Running without under tray
Old Jul 15, 2018 | 05:10 AM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
In hot weather it seems the engine compartment would cool faster if the under tray were removed to help convection out through the wheel area. There are some ventilation holes in the tray but they are small.
Has anyone run without it and if so, have you noticed any additional dirt collecting?
I’m not concern about the effect on aerodynamics at legal speeds.
Old Jul 15, 2018 | 07:40 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
Are you wanting the engine compartment to cool faster after stopping or trying to keep it cooler during driving?
The impact of removing the tray could be different in these scenarios.
During driving this might have an impact on the air flow through the radiators and turbo intercoolers. (might change the back pressure in the engine compartment not necessarily in a good way). Would be an interesting topic to research. Probably only be noticeable under very high engine loads.
Old Jul 15, 2018 | 08:01 AM
ace10's Avatar
ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !
It's very likely that Porsche engineers torture tested your car's design in condition far worse than you experience.
Old Jul 15, 2018 | 02:37 PM
riden's Avatar
My main concern is time-at-temperature. More time degrades organic materials like rubber and seals ( ac compressor seal for example). So anything that can be done to reduce the time at high temperatures will help. But you may be right that all of this is well considered for all climates but I have seen premature failure of plastic devices that contain check valves and other plastic parts in an engine compartment that had an under tray (not a Porsche). May chat with the Porsche techs. It could mess up some other airflow. Not sure.
Old Jul 17, 2018 | 09:16 PM
ciaka's Avatar
Short term (few days) I would run without lower engine splash shield. Ling term, would likely put it on, since small clearance and debris dknt mix well. Lots of stuff that can get damaged then you end up paying 3x the price and time.
engine does run hot, but such is Porsche life.
jaji
Jan 6, 2012 10:12 AM
shredder
Jul 19, 2011 03:21 AM
Nine_Eleven
Mar 19, 2011 10:46 PM
xcusemi
Dec 24, 2010 11:04 AM
