Is my Oil/Air Separator not working properly? Video Included
Old Jan 5, 2022 | 10:39 PM
  #31
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
i told mechanic to check the AOS so they will test it, i also remember that before my spark plugs had some oil residue in the threads and that is also a symptom of a failing AOS correct?
Old Jan 5, 2022 | 11:02 PM
  #32
newporsche's Avatar
5 Year Member
did your car have any other symptoms besides the high oil consumption when it failed for you? i also notice a bit more than normal tailpipe smoke when at idle or when reversing.
Old Jan 10, 2022 | 07:40 PM
  #33
newporsche's Avatar
5 Year Member
if there is oil in the intake manifold does that mean the AOS needs to be replaced?
Old Jan 22, 2022 | 12:49 PM
  #34
Porsche Pana's Avatar
Porsche Pana is infamous around these parts
Originally Posted by newporsche
hey there, i didnt end up changing the AOS because mechanic said, the amount of oil loss is within spec. have you experienced same sort of vacuum suction when you try to take cap off?
Yes, same vacuum as yours. I changed my AOS but still have the same vacuum as in your video. Could it be something else causing the big vacuum?
Old Jan 22, 2022 | 12:51 PM
  #35
newporsche's Avatar
5 Year Member
i just had mechanic replace the AOS i will report back if it improved, i do notice tho still a decent amount of exhaust smoke when driving, can see it in rear view mirror when im at stop light, is this normal?
Old Feb 7, 2022 | 02:10 PM
  #36
https://static.nhtsa.gov › odi › tsbs
SB-10051876-2657 - NHTSA
Old Feb 8, 2022 | 09:32 PM
  #37
newporsche's Avatar
5 Year Member
seems like that notice is for the suv not the panamera?
Old Feb 9, 2022 | 02:39 AM
  #38
Yes. But it's the same engine. I wonder
Old Mar 6, 2022 | 07:40 PM
  #39
SJ_Panamera's Avatar
SJ_Panamera is infamous around these parts
Just wondering - when doing this test (oil cap off) is it normal for the engine to run very rough once the cap is off? I recently replace my AOS which improved my idle and oil consumption but I've noticed the rough idle is back and I am starting to think my new AOS has already failed.
Old Dec 2, 2025 | 08:02 AM
  #40
master_328's Avatar
master_328 is infamous around these parts
Hey, when I don`t use my Cayenne 958 turbo for one week or longer, I get blue smoke (burned oil) out of the exhaust after startup. Everything else is running fine, no codes, no excessive oil consumption.
I also noticed a strong vacuum in the crank case – removing the oil cap with engine running is very hard.
I checked the membrane in the PCV – but no visible damage. Nevertheless, I replaced the whole PCV unit by a VAICO unit, but nothing changed. I still have this strong vacuum in the crank case.
Here my video:
Any idea?
V8Vdrew
Jun 15, 2021 05:59 AM
shadow993
Sep 25, 2018 03:58 PM
newporsche
Aug 25, 2018 08:40 PM
Cattman
Jan 18, 2010 07:42 PM
bond
Jul 15, 2004 12:59 AM
