Panamera Air Suspension System Info
Old Nov 15, 2019 | 10:22 AM
  #61
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Originally Posted by DogWood
best price on that tool seems to be Sonnen https://www.sonnenporscheoemparts.co...et-00072198250
$48
Looks to be a schrader valve adapter
but not idea how to use it, manual I have doesn't mention it at all
Thanks for doing the legwork on searching. Mazurda was the user that kindly shared his manual with me. It did not have any information on air suspension, only coil spring. I paid the piper $15.xx and pulled the instructions on replacing the strut. That’s where I got the bleeding and filling information too. I think I mentioned before they watermark the first page with your user id to try to discourage you from outright sharing their documents though....
With PIWIS you’re supposed to fill the system from the right front line up to 17 bar with nitrogen spec 5.0. Also notes somewhere to fill each individual strut to 7 or 8 bar using that adapter, I’m assuming after installation...
I’m about to take the car back to the shop and ask them to install the Unity strut. I know their price seems high but they are the only highly rated Porsche independent shop near me, that would even quote me a price. The dealers never called me back, even though I asked labor AND parts. I’m running out of time to get the SCITOO strut off the car and shipped back to Amazon...
Old Nov 15, 2019 | 02:05 PM
  #62
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
I vaguely recall reading something like that, and then promptly forgetting about because of the need for the PIWIS , even the clones are a bit spendy
If I get to that point I might try and make a manual controller for the valve block and do it that way.
Old Nov 25, 2019 | 12:56 PM
  #63
swdunne's Avatar
swdunne is infamous around these parts
Originally Posted by swdunne
Quick follow up. Through this entire ordeal the front left has been only corner down. We let the air out of right front and allowed to lower. Reattached air line and on the first cycle the front right came up a bit. Will let the compressor sit and will recycle. Because we still can't hear or see a leak in the front left we are contemplating removing the pressure lines to the front air bags back at the valve block and swapping to see if either of the sides will come up. We figure that if left front strut is leaking then it should stay down and right front should reinflate. If new valve block is bad then either the left front will inflate or neither will if the level sensors see the "wrong side" inflating and somehow stop it.
Brief update. Towed car back to Porsche Dealer last week and they have agreed to replace the front left strut with a new one under the warranty. Should have back in a day or two. A couple of interesting things. The Snap On Modus Ultra is able to command the individual struts to inflate and deflate. In my case the front left actually went up then after 10 minutes or so was flat again. Also, we looked up under the bellows that covers the airbag/strut interface and could see that one of the two black plastic tabs from the airbag to the strut was broken off. I would have thought those were really for locating the strut but apparently that is enough to allow it to leak. Finally, as we put air in the strut and tried different troubleshooting methods we never heard any air escaping nor were we able to see any air leaks while spraying every part of the strut with soapy water. We even did it with the car in the air, putting air directly into the air bag. Bottom line... If one corner is squatted all the way down, even if you just had them replaced, it's a bad air bag.... period, dot, end of story!
Old Dec 10, 2019 | 04:42 PM
  #64
PanameraGuy's Avatar
PanameraGuy is infamous around these parts
what issues did you have with RMT? I was curious if we are experiencing Same issues?
Originally Posted by Mazurda
Best of luck with RMT I had nothing but terrible customer service and issues with my struts from them after the sale. Had to send back twice and car was off the road for almost a month
Old Aug 15, 2020 | 04:59 PM
  #65
bass514's Avatar
bass514 is infamous around these parts
Originally Posted by ciaka
Regulate compressed air not to shoot 250psi for too long. Low pressure for a second and block with finger to see if shock keeps air or get rubber grommet to plug.
I did with my shocks before install. Gentle.
If you installed new compressor, assuming that's all that was wrong, it will take several cycles to air up suspension.
Make sure you clear out errors using your dials tool.
Do it once while car is on, and once while off in acc mode.
Compressor only airs u air tank (aka accumulator).
Ecu tells valves to open or close to put or remove air from shocks.
Compressor runs less than 1 mon at a time to prevent thermal overload.
Let us know what you find out.
Hi Ciaka, thanks for all the useful infos you provide on this forum.
I just wanted an advise if possible. my 2012 panamera 4s had the chassis failure, I did notice that one corner of the car(Front left) was lower than the others. The Porsche dealer told me that I have to change all the height sensors. my question is : wouldn't it be enough to change the sensor of the corner in question? just dont want to get ripped off.. lol
thanks for your time
Old Aug 15, 2020 | 05:55 PM
  #66
ciaka's Avatar
It will be easy for you to tell. Open the hood, remove the triangle trim on either side of hood (where tops of shocks are), use soapy spray to spray water on the air connections and on the top of the shocks. Refer to the air suspension thread for details on how to do it. Once you spray, if you see bubbling, you will know that the system is leaking air.
Think what the mechanic said. Said the height sensors need replacement. Would a height sensor make your car go lower over time? If your height sensor is damaged, it would stop reporting to the ECU on height of the car, and you would have a permanent air suspension fault on your cluster.
As I understand, you drive car, park it, and after some time, the front dips (and you can see because at least one of your front wheel wells are much closer to tire after some time).
Would a defecting height sensor cause the suspension to be lower over time? Chances are not. If you see bubbling top of shocks, it is your 100% proof that you have an air leak. If you do not, there is a chance sensors going bad, but sensors do not go bad, and keep working. These height sensors, get broken, get electrical connection interrupted, the mechanism stops working, but I have not heard of such sensor work to lower your car too much and only after some time passes (a day or so).
Common sense here tells me air leak first, sensor not likely bad. You have to do the check though. Use the thread and do the troubleshooting yourself. Dealer will be more than happy to take 750-1k off your hands for parts and labor to replace both front sensors.
Let us know what you find.
Old Aug 15, 2020 | 05:57 PM
  #67
ciaka's Avatar
Remember, the compressor does not put air into the shocks. The compressor only tops up the air tank that is under your car, where compressed air sits, and when ECU and sensors detect your car get lower, they open valves at the valve block, and the shocks in need to put air from the air tank, into the shocks. Or if too high, the same valves open to drain air out of shock into air tank.
Quick update. Put air in the strut, lifted car a bit and put thumb over the valve. Car didn't sink and could not hear anything leaking out. So then we put a gauge on the line to the front left and turned system on. Confirmed we got air to the line so valve block functioning. Hypothesis now that strut is OK but compressor not generating enough pressure to lift car and so when compressor runs front corner does not lift computer shuts the compressor off and gives chassis failure light. Should have replacement pump today to verify this. Will post update when we know more.
Old Aug 15, 2020 | 05:59 PM
  #68
ciaka's Avatar
These air shocks sometimes leak from under bellows, internally. You wont be able to see any bubbling this way. Only if leaking from top of shock will you see bubbles in a leak.
Just a bit of info. Thanks.
Old Aug 16, 2020 | 03:54 PM
  #69
Stringbag's Avatar
Stringbag is infamous around these parts
Excellent info here too.
https://www.6speedonline.com/forums/...out-seals.html
similar thread by the same OP on Rennlist.
Old Feb 15, 2021 | 04:10 PM
  #70
stealthn's Avatar
stealthn is infamous around these parts
If the system is not leaking, for example you need to replace the valve block, how do you drain the system considering the high pressure?
Old Feb 15, 2021 | 04:15 PM
  #71
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Pop a connector off. It's not going to explode.
Old Feb 15, 2021 | 04:25 PM
  #72
swdunne's Avatar
Agreed, just loosen any of the air lines and let the air bleed off. No sweat
Old Feb 15, 2021 | 05:08 PM
  #73
ciaka's Avatar
If you're just replacing valve block, I would put jacks under front so they don't bottom out. Or anything that will safely keep shocks from bottoming. Then loosen any line ( my thread tells you what line connects for what. Make sure you disable suspension before start.
Old Feb 15, 2021 | 11:11 PM
  #74
jzchen's Avatar
5 Year Member
Officially you use PIWIS or an equivalent tool to bleed, and then fill the system with N2 gas. It is not clear whether you can replace the valve block without losing some N2.
I was able to depressurize one air strut and then refill it without losing much, if any, N2, with a Foxwell NT510 Elite. (I heard a tiny bit of gas escape when I loosened the air line to the strut).
Old Feb 16, 2021 | 02:37 AM
  #75
Stringbag's Avatar
Same with Icarscan. Just follow the procedure in the tool. You’ll need it if you re-pressurise with N2 (if you are going to do that.)
It pumps the N2 into different places and closes the valves so as not to loose any.
definitely four axle stands - the bags need to ‘dangle’.
