DIY: Front airbag replacement. Also IMPORTANT info about seals
Old Jul 14, 2020 | 05:32 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Backstory - front suspension was leaking. Soapy water showed bubbles around and at the top shock nut. Common thought is that the rubber around the center collar cracks and allows air out. (That or the bag itself pops...rare...) I'd like to suggest a third and far cheaper culprit: the top o-ring seal. The airbags themselves are NOT a sealed unit. They use the body of the shock to seal against with o-rings. One at the top, one at the bottom. After doing this work, I think my leak was the top o-ring seal ($15) and the measurements - pictured below - kinda back me up on this. After the work was done, I noodled on a way I could have tested the top seal. I think I came up with a way to determine if your leak is the bushing or the top seal:
If the leak is coming from the center seal, the air will be escaping from underneath the center shock nut. If it is leaking from the bushing, it will be leaking from the bushing - which is 1/4" or so of rubber between the collar and the bag housing.
Get a bowl of soapy water. Literally a bowl with 1 cup of water and a good amount of dish-soap. Mix it up without making a lot of bubbles. Get a small paintbrush. Like small-small. An artists detail brush or something from your kid's watercolor set. Using the brush, carefully and sparingly dab some of the soapy water on THE BUSHING. Try to keep the water to just the rubber. It's concave, so this isn't as difficult as it sounds. It should want to sit in there. Bubbles? Your bushing is leaking. No bubbles? It's the seal.
I wish I would have thought of this before getting new airbags. It should be standard operating procedure for anyone looking at a leaking front strut. The seal was $15. The bag (from Porsche) was..... a lot more.
ANYWAY - on to the DIY!
Some tools and parts you will require for this job: One good ratchet strap. Set of 1/2" and 3/8 sockets. 15/16" socket. Torque wrench. Tie-rod ball joint puller (can get from Autozone for free). Floor jack AND a small bottle jack.
Must haves: This is the socket to remove the top-nut. You put a 10mm on the shock itself to keep the shaft from turning, and then use a 1/2" socket on this guy to actually turn the nut off and then on.
Pelican Parts. $15 Direct Link
Another must have - CV strap pliers. $40. Amazon
Last must have (besides patience) - Wiper arm puller. $30. Amazon.
Here is the parts list of things you will need IN ADDITION TO the bag assemblies:
I looked at the other shock removal thread for inspiration, but came up with a better and faster way to get the strut out. Turn off the suspension, jack the car up, remove the tire. Unplug suspension sensor on the top a-arm. Unplug ABS sensor. Unclip the ABS sensor lines from their holders and get them out of the way. That's all just like the other thread - from here things differ a bit. I started on the driver's side because it's a bit more difficult.
Under the hood, remove the coolant cap, and using a T25 torx, remove the 3 screws and remove the cover/panel
Pop-off the wiper arms, and leave the cowl cover attached near the windshield. Lift it up the cowl on the engine-side and look for the three T30 screws holding the plastic piece (yellow arrows pointing to it). Blue arrows point to locations of the T30. Remove these and put them in your bolt-box. Note that these T30s are snub nose. The T25's from the previous step are pointed.
Once that is removed, you'll have clear access to the three strut mount bolts (must be replaced with new), and the various pneumatic and electronic connectors to the strut. Use a greenie (small flat screwdriver) and carefully disconnect the electronics to the strut. Using a 12mm wrench (ideally, a line-wrench), loosen and remove the air-line going into the strut. It will hiss and pop out followed by a gush of air, unless your system is completely flat.
Get a 16mm socket and loosen all 3 strut nuts until the stud is about halfway out of the nut. (NOTE: Original nuts are 16mm. The factory replacements are 15mm). Doing this will allow the strut to hang down and create a gap between the top of the strut and the body of the car. Now carefully fish through the gap between the strut and the car one end of your ratchet strap assembly. Try to go between two of the studs and avoid the area with all the connections. This is how I routed mine. Pull the non-hooked end all the way through, and then hook the other side to one of the legs on the lower mount of the strut.
Hooked:
Now get your bottle jack and pop it underneath the lower control arm, near the mount for the lower strut. Put a bit of pressure on the LCA. This pic shows it later in the job so there's a good amount of pressure.
Now get your 18mm socket and remove the nut on the tie-rod ball joint, and the swaybar link. The swaybar link has a nut and a bolt. The bolt is 16mm and the nut is 18. Remove the nut - not the bolt. The bottom strut bolt is a 15/16 , the nut is 18mm. Do NOT remove the lower strut BOLT yet. DO remove the nuts from the lower strut bolt, swaybar link, and tie-rod. Using your tie-rod removal tool, position it on the wheel carrier and put the fingers of the puller on the ears of the wheel carrier. Start screwing down the plunger of the tool. Get a GOOD amount of pressure on it, but not an ungodly amount - you don't want to damage the balljoint, the threads, or break the tool. Now, under pressure, get a flat-face hammer and whack the side of the carrier right where the balljoint goes through. 2-5 good hits and that thing will pop out with a bang. Move the tie-rod out of the way.
Puller/press installed:
Start jacking up the lower control arm. (Yes, the ratchet-straps are still dangling...). Jack it up a pretty good amount. Like almost all the way up. Once it's topped out, Get the ratchet-assembly of the strap. You've got one hook already connected so connect the ratchet-side hook to the opposite finger of the strut mount. Here you can see the other side hook, and the ratchet.
Now, with the suspension fully compressed, ratchet down the strap until its tight. You have now locked the strut into the fully compressed position.
Let down the bottle jack a bit and you'll find the sweet spots where you can just pull out the swaybar end-link and lower strut mount bolts. Now the only things holding your strut in the car are the three top mount nuts. BTW - why do you need to remove the tie-rod ball joint? Because some Porsche engineer was a dick:
Fully release the bottle jack.Go back up top and remove 2 of the three nuts. As you start working on the third, reach around and put a hand on the strut so you can catch it as it falls out. When the nut pops off, the strut will drop. Using the bottle jack again, find the area in the suspension travel where you can wiggle the strut out. You'll have to fiddle with it a bit. On mine, I had to get the lower fingers of the strut pulled to the side. Then I jacked up the LCA a bit to open the gap at the top between the UCA and the strut. Trust me - you'll figure it out. It takes about 30 seconds of jack-stuff. On the driver's side, it comes out towards the car. On the passenger side, it comes out towards the front bumper.
Believe it or not, I was able to do ALL of the above steps in 22 minutes on the second strut. It's not that hard and using this guide will really speed you along.
Now the strut is out. Remove the ratchet strap. Using the special socket and the 10mm wrench, loosen the center nut. I used the leverage of the ground against the 10mm to break it free.
Once the center nut has been removed, using a flathead screwdriver, pry the tab of the metal strap holding the top of the bellows to the airbag housing. It will pop off. Slide the bellows off the airbag housing.
This next step sounds weird, but it works. Get on the floor with your strut. Put the bag-side away from you and have the forks pointed at you. Put your feet on either side of the bag housing, and give the forks a good tug. You will pull the actual bag inside out and this will let you get to the next step.
There are two plastic fingers inside the metal part of the airbag housing. These fingers attach the airbag to the shock itself. Wedge nylon screwdrivers or something similar between the fingers and the metal of the strut. They are pictured here:
With the fingers pried out a bit, do the same thing you did to overextend the bag. Give it a good, sharp yank and the bag will pop off the shock. Here you see the lower seal on the shock. This seal and the top seal are what actually keeps the air inside your airbags.
Here's the top-seal - and where I think my leak was coming from. You can see the seal has flattened out along the top edge.
Old seal thickness;
New seal thickness:
The lower seal showed slightly less shrinkage. Both seals were dry and deformed. I can't say for sure, but I think my leak at the top was due to the seal getting hard and shrinking.
CLEAN CLEAN CLEAN. Installation of new seals requires cleanroom levels of clean. No dust or dirt if at all possible. Use a nylon pick and remove both seals. Lacquer thinner and a lint-free cloth will make quick work of the seal channels and the upper part of the strut shaft. Clean them well. Get some dielectric grease which is the same as the Porsche spec'd grease and lube up the seals. Goop some DE grease into the o-ring channel. Slide them into position, and then apply more dielectric grease to them, as well as the top part of the shock where it goes through the bag housing.
Get the new bag and pull the lower part of the bag out like you did above to get to the ears. It'll look like this;
Slide your new bellows onto the shock, narrow side towards the fingers. Put the strut fingers-down on the ground, and slide the new bag over the top. Thread a NEW nut on the top until its finger tight. Flip the strut assembly over. Get your ratchet strap out again. Loop it over the top and between the fingers of the lower mount and start cranking it down - watching the clips slide up the side of the shock. They won't clip in. Use two sets of pliers, one each at 45-degrees from each of the clips - one on either side of the plastic clip/mount and pull UP on the plastic bag-housing and the ears will click into place. Loosen the ratchet strap. The fingers will keep the shock from popping back out.
(Now is a great time to go back to the car and make a mental note about which side of the strut the swaybar end-link bolts to. Then go back to the strut on the bench and make sure the orientation is correct as you're setting it up. Learn from me. I didn't do this and got lucky on the driver's side. Not so lucky on the passenger side. Wasted another hour taking the strut back out, taking it apart, flipping the ^&*(Q)$ thing around, etc...)
Use the CV strap pliers and fasten the bellows to the strut.
Using the same setup you used to remove the top-nut, install it. Torque it to 41 ft-lbs. Use your ratchet strap to compress the assembly again. This will also flip the bag right-side-in. Installation is the reverse of removal - with the exception of FLIPPING AROUND THE DAMN LOWER STRUT MOUNT BOLT so it can be removed without pulling the tie-rod.
Torque specs for everything are in the other strut removal thread. IMPORTANT: Do not torque down any suspension components unless there is a full load on the suspension. Tightening fasteners on unloaded suspension parts is an amazingly efficient way to destroy bushings really quickly. Put the bottle jack back under the LCA and lower the car to where it's at normal ride height. Measure the distance from the floor to the center of the wheel and replicate that measurement from the floor to the center of the hub by jacking up the bottle jack. NOW go ahead and torque down the swaybar end link and the lower strut mount. The tie-rod doesn't really care if its loaded or not, but I always tighten it at the same time.
Do one side at a time. Once everything has been re-installed on one side, DO NOT put the covers back on underhood. Put the tire back on and using your floor jack, lower the car until it's just a smidge below level. The jack will still be supporting the weight of the car. Do not let the car all the way down. There's no air in the bag - it'll just slam into the bumpstop. No bueno. Get in the car, close the door, and start the car. Re-engage the suspension and set it to "comfort". The pump will run for a bit, fill the bag, and level the car - lifting it off the jack. Shut the car off. Get some soapy water and check all of your connections for leaks.
Torque lugs to 100 ft-lbs.
It took me 3.5 hours for the driver's side - taking pictures and "trial and error" stuff, and about 2 for the passenger. Most of the passenger side was because I f-ed up by getting the orientation of the swaybar end-link ear wrong. Had I not screwed that up, I bet I could have gotten the passenger side done in 90 or less.
No leaks.
Your mileage may vary. I make no guarantees. That said, I bet my leak was my $15 seal.
Edit: Its been 6 months now - no leaks.
Old Jul 15, 2020 | 06:34 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Thanks for taking time to take pictures and describe important points along the way!
It’s nice to see how some of the parts assemble, the Porsche instructions show nil....
Old Jan 10, 2021 | 09:46 PM
jzchen's Avatar
5 Year Member
I get an email about your posts on ciaka's thread but some how this is the 2nd one that's disappeared.
Brilliant idea to switch the bolt and nut around, and thank you for sharing the 15/16" tip. Strangely I stumbled upon the size because I just so happen to have a combination wrench leftover from prior car work. Sadly, I did not swap the bolt and nut around next time if we even still have the car I will have to pop off the tie rod ball joint which I hate with a passion.
Do you have a Schwaben part number or link to where you bought it? I like that you can use a torque wrench on it.
​​​​​​I think you stumbled upon a possible failure cause, which is suspending the car with wheels/suspension dangling. That little rubber area that you noted as concave is not actually concave with the car sitting on the wheels. It is flat normally. I noticed when I raised the car this time my right front even though overinflated via bleeding the left front was concave as well. I ended up supporting it on the slope of a Rhino Ramp which alleviated the concave shape some. I could see some pressure due to the angle of the slope but it looked better than concave...
I'm afraid I have my doubts about that little ring holding all that air pressure in. I suspect it does help keep the top of the bag in place when jacking the car up.
​​​​​​One other note:. I had to look up the torque spec for the wheel bolts and my owners manual notes 118 ft*lbs. Just an FYI I guess 100 is enough.
Old Jan 11, 2021 | 07:11 AM
shrike071's Avatar
Originally Posted by jzchen
That little rubber area that you noted as concave is not actually concave with the car sitting on the wheels. It is flat normally. I noticed when I raised the car this time my right front even though overinflated via bleeding the left front was concave as well. ​​​
The bushing at the top that surrounds the shock-stem? It is concave on my car - sitting on the ground or not, even with the new bags installed. There are most like varying casting differences that may make some flat and some concave. I just went and checked the old/OEM bags (sitting on the workbench) and they are also concave.
It is a seal. It is one of two seals that seal the shock-stem against the bag, and listed as such according to Porsche. One at the top, and one at the bottom. There are no other seals in the assembly.
Here is a direct link to the socket for the strut
It is Schwaben Part 003046SCH01A-03
Is your car back on terra firma?
Old Jan 11, 2021 | 08:10 AM
jzchen's Avatar
5 Year Member
Thanks so much again for the help and fast response! I guess that is the seal. (My apologies for doubting you).
​​​​​​Yes, it is finally down. It looked like a disaster with all the lifts supporting the body and the suspension. Today I already started maybe at 6 (it was still dark I had my headlamp on). Last night I posted a thread on a code my Foxwell found 000268. I don't know if I accidentally posted in another section of the forum, but I do not see it here in the Panamera side. Foxwell deleted the code but it would immediately pop back up on rescan. This morning I took my PIWIS to the car and only found U0418 IIRC, which was PDK fault memory (with no active faults), so I believe I'm in the clear. I thought I might have damaged the hood wire harness on the right side taking the cowl panel off...
I must say the Arnott new strut is HEAVY, at least for me. It makes the old original feel really light. My arm scale says maybe double the weight. I hope it doesn't affect dynamics much, because the reason I opened her up in the first place was she was driving funny on the freeway, like damping front left vs front right was different. One side more bouncy (the left) than the right (replaced bag and upper control arm Nov 2019).
I replaced the upper control arm as my primary goal, then told my wife since this is so much work let's replace the strut while I'm in there. (I'm so glad she agreed).
I'm assuming you did not touch the brake caliper? I ended up following the Porsche instructions and moving it to the right side of the wheel well (with my wife's help) and just sitting it on a box. Those bolts are noted as one time use and should be replaced. The dealer gave me the wrong bolts. I already turned off the suspension. Going to pull the wheel and then take one bolt with me this time! (Argh).
So one note about turning the suspension off. Last time I just turned Ig-ON but did not start the engine. Maybe that was a mistake as this time I started the engine. Car lowered immediately upon deactivation.
Old Jan 11, 2021 | 10:12 AM
shrike071's Avatar
I removed the caliper and hung it off to the side using caliper-hangers. You can use coat-hangers in a pinch, they work just as well. I am going to be pulling my UCA's soon and replacing them due to squeaking, so I'll be back in there myself. I am not really certain how the deactivation responds to the key because I have yet to turn the ignition back on before the job was complete. On my car, turning it off doesn't raise or lower it at all. I believe it just turns off the control function and ignores whatever position the bags are in. YMMV
Old Jan 11, 2021 | 12:02 PM
jzchen's Avatar
5 Year Member
I'll update the UCA thread if I don't see it there, but you can't really see anything wrong with the bushings just looking at it while installed. The tech who replaced the bag advised me to replace it just by looking at it, installed. He said when it is loose like that then it should be replaced. Once you swap in the new one and tighten to spec it will stay in place, for example if you tightened it while it was horizontal it will stay horizontal. I had put it at a slight angle and needed significant force for it to clear the top of the strut as I inserted it. As soon as I release the new rubber bushing forced it back into the original position.
Old Jan 11, 2021 | 12:03 PM
jzchen's Avatar
5 Year Member
Duplicate post...
Old Jan 22, 2021 | 11:17 AM
Nikita4Ever's Avatar
Nikita4Ever is infamous around these parts
@shrike071
Did you ordered the Porsche specific nuts, bolts, clamp, etc from Pelican Parts?
I have the quick jack lift but it looks like I still need that bottle jack?
Old Jan 22, 2021 | 01:13 PM
shrike071's Avatar
Originally Posted by Nikita4Ever
@shrike071
I ordered my parts from both Pelican and the dealer. The bellows and some of the nuts and bolts were actually cheaper at the dealer. You can see what I ordered at the dealer in the receipt above. I have since ordered a quickjack - wish I'd have had it for this work! That said, you'll still probably want a bottle jack for the LCA work.
Old Jan 22, 2021 | 06:13 PM
jzchen's Avatar
5 Year Member
The only problem I had when I considered the Quick Jack is it comes in many lengths. I have a Scion iQ and it would not work for both that and a Panamera. Probably need to resort to a serious lift...
Some kind of lift with a screw drive was helpful to adjust the hub center to bottom of fender at 404 mm +/-10, (with rubber pad to not mar the LCA). With a hydraulic jack it's easy to adjust up, if you need to lower screw drive is easier than releasing hydraulic pressure.
Old Feb 23, 2021 | 01:48 AM
I've purchased all of the required Porsche parts and tools but not the “bag assemblies”. What are these? Can you provide the part numbers?
I'm ready to tackle this job.
Old Feb 23, 2021 | 02:20 AM
jzchen's Avatar
5 Year Member
One of the dealers near me is good at giving part numbers so I can't confirm accuracy, but:
​​​​​​https://nemigaparts.com/cat_spares/p...0/535u/402050/
Old Feb 23, 2021 | 05:22 AM
shrike071's Avatar
For mine, the left was 970-343-151-04 and the right was 970-343-152-04
Old Feb 23, 2021 | 11:09 AM
jzchen's Avatar
5 Year Member
Mr. V, I can honestly feel the damping difference between front left, (the new Arnott complete strut), and front right, (original strut with bag replaced last November), with less than 50k miles. If you have a leak in both sides I highly recommend replacing the whole darn "quick strut" on both sides. It is also highly likely you want to replace the upper control arms (Porsche calls them trailing arms) if you have a crunching noise. Crunching sound went away after replacing the respective sides.
Best of luck!
