Porsche Gasoline Additive review
hey all, i just picked up some Porsche branded gasoline additive. its a small 100ml bottle, ill report back if i notice any differences in using before i fill up, its over 20 dollars per bottle so quite a bit more than the techron stuff
Yes please let us know. However, I believe if you use the highest octane from a premium supplier, like Shell, you don't need any gas additive.
What is the additive supposed to do any way?
Gas additives (not octane booster) are like fuel detergent additives that are in Top Tier Gas brands. The additives help to address carbon build up on the intake valves. Discussed elsewhere regarding carbon build up on intake valves, Panamera has Direct Gas Fuel Injection (DGFI) in which the fuel is injected directly into the cylinder and after the intake valves. The fuel additives provide little or no benefit for DGFI engines.
