Comfort setting not saving
Old Nov 19, 2018 | 08:08 PM
stealthn's Avatar
stealthn is infamous around these parts
Hi,
so I changed the comfort entry NOT to move the drivers seat but it still does it. I even disabled it and did a Set 1 on the door to see if that would save it, no luck. It does seem like a couple of settings are not being saved.
thoughts?
Old Nov 19, 2018 | 08:38 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Once you changed the setting in the instrument cluster did you also save it on the door key setting? That’s the only thing that comes to mind...
Old Nov 19, 2018 | 09:32 PM
stealthn's Avatar
Yes, both
thanks
Old Nov 23, 2018 | 05:18 PM
stealthn's Avatar
Update: it saved it, probably the 10th time I set it, but it stuck this time. Weird
Old Nov 23, 2018 | 07:48 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
my car does the same thing, seems to take several tries to get it to take some settings, very odd.
Old Nov 24, 2018 | 06:45 AM
mziegler38's Avatar
mziegler38 is infamous around these parts
My service adviser told me to (after a setting change and saving to the key panel on the door switch ) to click the actual key "open button" 3-4 times to save the setting.
Old Nov 24, 2018 | 07:28 AM
stealthn's Avatar
That would make sense why mine stuck, but now I have to test this
Dpm7471
Macan
Feb 12, 2016 07:35 AM
JoeInDallas
Nov 5, 2013 10:02 PM
rnl
Jun 20, 2013 07:37 AM
rnl
Jun 27, 2012 09:04 AM
RobsCountach
Cayenne 955/957
Jan 4, 2011 10:52 AM
