Stereo changing pitch bia bluetooth?
Old Dec 23, 2018 | 10:04 AM
LouDA's Avatar
LouDA is infamous around these parts
Has anyone had this problem before? Any audio guru here to help?
Got in the car this morning and started playing music, per usual via bluetooth. It is a little bit colder than usual - 32 degrees if that has any bearing. My speakers are rattling a little as well as the pitch was changing ever so slightly, like an old casette. Lower pitch at first then as it settled in, raised the pitch, then back down and up again and its remained steady. Most would just ignore it I am guessing, but I am a musician and it has bugged the crap out of me 😁
Baffled at how that can happen via bluetooth. Anyone know?
Old Dec 24, 2018 | 01:19 PM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
The Burmester system in my car is fantastic, but there is a noticeable degradation in sound quality when I play music via Bluetooth. I now use the Aux input and the sound is incredibly clear - I hear absolutely everything on the track. You might want to try the Aux input to see if it helps - if not you'll know it's something more serious.
Old Dec 25, 2018 | 01:15 PM
LouDA's Avatar
I will give that a shot... have the Bose and not the Burmester but sure it's a similar result. Thanks!
Old Dec 25, 2018 | 02:51 PM
dudecs's Avatar
dudecs is a jewel in the roughdudecs is a jewel in the roughdudecs is a jewel in the rough
Whether you have Bose or Burmester, you will have better audio fidelity with a hard wire connection versus Bluetooth
dmvcarlover
Lamborghini
Mar 23, 2017 01:18 PM
sendtobrit
Aug 14, 2011 09:45 PM
stevo996tt
Apr 21, 2008 10:35 PM
Oweyea
Mar 26, 2005 10:00 AM
