Interior LED swap problem
Old Feb 2, 2019 | 10:42 PM
  #31
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
I want to see pictures of that, sounds cool
Old Feb 2, 2019 | 11:08 PM
  #32
970gts's Avatar
5 Year Member
970gts is infamous around these parts
LED lights
I put 4 of the Oznium surface mount LED in the trunk of my A3 and 8 of their Superflux in each foglight grill awhile ago. They worked great and were easy to wire up. Good luck with your project.
Old Feb 3, 2019 | 12:56 AM
  #33
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Good to know, I ordered the 7.5 inch strips...I hope that is not too bright for the spots I want them in (door pockets and under the dash)...only one way to find out! I’ll post pics once installed. For now I’ll start looking at what else I need to power them up, the strips just come with the two wires on both sides.
Old Feb 4, 2019 | 02:37 PM
  #34
Kayvan1347's Avatar
5 Year Member
Kayvan1347 is infamous around these parts
hi
i changed all the interior LED pulls and the works great. I am still working on the Dime light though.
like to do put some strip Led on pocket doors and around console.
Could you provide more detail su as the Ed act strip that works and where you hooked the wires for peer. If any one can help would be appropriate it.
Old Feb 4, 2019 | 05:34 PM
  #35
LouDA's Avatar
LouDA is infamous around these parts
Originally Posted by Kayvan1347
hi
You should have two front metal clips that look like a V shape. They ping off easily when you pry the front section of the dome light down so see if anything is rattling around in there. They slip over the white plastic clip-like pieces. Will try and take a pic tomorrow.
Old Feb 4, 2019 | 05:51 PM
  #36
Kayvan1347's Avatar
5 Year Member
Hi thanks for the info. I figured it out how dome light assembly is. I think the metal brackets already bent and stuck up there. I will try to work around it to see if I can remove it.
also if you know how instal LED strip on the doors and main console, I like to do that too.
Old Feb 4, 2019 | 11:56 PM
  #37
Kayvan1347's Avatar
5 Year Member
Hi everyone,
finally I could change the LED bulb on the dome light . Basically I had to rip it off down. In my case all 4 brackets bent. I am actually very upset about the whole things. Someone made video and it is the only video on the Youtube regarding the Panamera Led update. I think everyone like me saw that and start breaking down the dome light while to change the bulb on dome lite you don’t even need to take the whole console down. Unfortunately I figured it out after the fact.
To change the bulb on Dome light you just need to remove the cover frame and then the U shave white plastic that is under the first cover. It is that simple. It is literally few minutes job. But my case toke several hours to bring down the whole console and the try repair all the brackets and put them back up.
i hope this help other doing the right way.
cheers
Old Feb 15, 2019 | 10:58 PM
  #38
Kayvan1347's Avatar
5 Year Member
Hi all
i changed all the interior bulbs to LED. And it looks great. I only have one issue though. The rear reading light sometimes don’t work. I don’t know why but sometimes works and sometimes not. Is that just me or it happened to anyone else too. Any solution?
Old Feb 15, 2019 | 11:00 PM
  #39
DogWood's Avatar
5 Year Member
I haven't experience that problem, all my lights work fine, perhaps its a bit loose?
Old Feb 15, 2019 | 11:54 PM
  #40
Kayvan1347's Avatar
5 Year Member
I thought so too so I open and reinstall both of them. Interesting that when they don’t work both of them don’t work at the same time???
Old Feb 16, 2019 | 08:54 AM
  #41
DogWood's Avatar
5 Year Member
that is odd
Old Feb 16, 2019 | 09:37 AM
  #42
Kayvan1347's Avatar
5 Year Member
I got the led bulbs from Amazon. Did you use the same bulbs too?
i have a feeling there is a pattern when is happening but I haven’t figured it out. When I unlock the doors all lights gets on, but sometimes before I start the engine the two readings lights gets off and won’t turn on again. I have turns the car off and on and lock and unlock the doors then they back to normal. I think it has some compatibility issue.
Old Feb 16, 2019 | 09:45 AM
  #43
DogWood's Avatar
5 Year Member
which lights did you order?
I used these for most of my interior
Amazon Amazon
Old Feb 16, 2019 | 11:06 AM
  #44
Kayvan1347's Avatar
5 Year Member
Yes I used the same bulbs.
If I am not mistaken it happens when I start the ignition with driver door open. Sometimes I do that , I start before I close my door. I am not sure but I will check and post it again.
Old Feb 16, 2019 | 06:13 PM
  #45
Kayvan1347's Avatar
5 Year Member
I checked it. Yes it happens when I start the car with driver door open. I usually do that if I am in my house garage , and I t didn’t happen before with halogen bulbs. But it doesn’t matter I finally figured it out. I have to start with close door.
