Tpms problems
Old Jan 25, 2019 | 01:19 AM
turbo_mikePTT's Avatar
turbo_mikePTT is infamous around these parts
Tpms problems
Anyone else have tons faults in their Panamera mine is a 12 TT and it keeps giving me a fault some times reading -7 psi.
Old Jan 25, 2019 | 01:53 PM
ciaka's Avatar
Mine seems to be working just fine. It is possible your TPMS sensor(s) going bad (break or battery bad). It would mean you would have to pull tire off and service the module in the wheel, then put tire back on.
Best done when you are changing tires, or you will have charges (probably about 20 bucks for tire un/mount, then maybe 50 bucks for pd and service. If module needs replacing, you would have to add that cost as well.
Old Jan 25, 2019 | 03:34 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Durametric tool or dealer tool can plug in and tell if batteries going bad. If they are original that could be it.
Old Jan 25, 2019 | 08:11 PM
Boxzing's Avatar
Boxzing is infamous around these parts
Batteries in the TPMS last around 7 years.
Old Jan 26, 2019 | 09:22 AM
ciaka's Avatar
Any tire shop can at no charge scan your tpms sensors and tell you if batteries low. Go to one and ask. 2 minute check. Good luck.
Old Feb 2, 2019 | 10:42 AM
Ok we will check it out.
rossyl
Sep 28, 2016 07:54 PM
Brady Miklos
Cayenne Turbo
Jul 19, 2016 11:51 AM
HOiYA
Cayenne
Dec 10, 2014 02:26 PM
JEllis
Jan 7, 2009 10:11 AM
