Injector noise
Old Feb 11, 2019 | 04:41 PM
rad288's Avatar
rad288 is infamous around these parts
Injector noise
For the past month I’ve had a noise coming out of the engine area. It sounds like a sewing machine (literally). I took it in and was diagnosed as noise coming from the injectors. I was happy that they found out what was causing the issue, right until they told me that Porsche said it is normal. Anyone else have this noise issue? Mine is a 2017 Panamera 4S with 9000 miles on it.
Old Feb 12, 2019 | 05:54 AM
fgv1it's Avatar
fgv1it has a spectacular aura aboutfgv1it has a spectacular aura about
Yes, it is a known characteristic of direct-injection engines. In these engines, the injectors work at high pressure in order to inject the gasoline directly into the combustion chamber. The high pressure operation causes the noise that you are hearing. Whether or not you actually hear it in a specific car depends on the injectors themselves, their position in the engine compartment, other noises produced by the engine, etc.
santklein
Bentley
Nov 15, 2020 12:36 PM
Ms4cd
Jan 11, 2015 10:02 PM
Mother
Tech / How To
Dec 17, 2005 07:03 PM
