Brake Pad Worn Red Notification
Old Jul 16, 2019 | 07:12 AM
Mazurda's Avatar
Mazurda is infamous around these parts
Does anyone know at what MM measurement the senor triggers this warning and how much time I can drive the car normally to and from work, approx. 50 miles a day mostly highway. Thanks in advance.
Old Jul 16, 2019 | 07:23 AM
Mazurda's Avatar
I would like to add the pads were allegedly replaced at 43k miles, ca now has 46k miles. Could even a terrible brand have this short of a lifespan?
Old Jul 16, 2019 | 10:48 AM
XLR82XS's Avatar
Road use: most likely not.
Track use: can be worn out in a few HOT laps.
Old Jul 16, 2019 | 10:51 AM
Mazurda's Avatar
Parked car, went out for lunch and message went away. Pads are low for sure, just didn't expect that so soon , thinking the service wasn't even performed. Carfax isn't always accurate I guess
Old Jul 17, 2019 | 04:44 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
The instructions don't specify the difference between warning start to minimum thickness (2mm), but notes don't go below 2.5 mm if you want to save the sensors from needing replacement. Basically 2.5 mm if you don't want to replace the sensors. 2 mm minimum thickness. (I have no idea how long that would last your type of driving I'm afraid).
If you don't mind the hassle of shipping them back, you can get free replacements after purchasing a set from FCP Euro. (I just received coolant from them. Geez OE pads are quite expensive.) I'll probably be happy with AutoZone personally...
ILikeEsses
Apr 26, 2014 07:40 PM
donshin
Jun 5, 2009 01:53 AM
BCS996TT
Aug 24, 2004 10:02 AM
BCS996TT
May 8, 2004 08:47 PM
