Broken Ride Height Level Sensor...Help
Old Oct 22, 2019 | 07:47 PM
Mazurda's Avatar
Mazurda is infamous around these parts
Rod broke off from sensor and is just hanging. Can't seem to find this part aftermarket, or just the rod alone? Anyone have a good source for this piece with expedited shipping? Ebay has them (mostly preowned) but I need something by Friday. Any help is appreciated
Old Oct 22, 2019 | 07:57 PM
ciaka's Avatar
That will be tough. If you need asap, maybe you can call the dealer and swallow the cost if this is super urgent. They normally stock stuff like this.
Hope this helps.
Old Oct 22, 2019 | 08:00 PM
Mazurda's Avatar
Hope this helps.
That will be last resort for Friday, going to need to get a compressor just to inflate the front bags, typical jacked up rear and slammed front from this break
Old Oct 22, 2019 | 08:02 PM
ciaka's Avatar
call them now to make sure they have in stock. they can order and have ready if you need by Friday. Just in case.
Old Oct 22, 2019 | 08:05 PM
ciaka's Avatar
Idea: Have you tried removing sensor and using JB WELD to glue together, leave out overnight then install next day? The bar does not experience lots of force, so should be just fine.
Old Oct 22, 2019 | 08:08 PM
Mazurda's Avatar
That's what was used, just don't think it had ample time to set...may need to explore that route temporarily thanks.ciaka
Old Oct 22, 2019 | 08:09 PM
ciaka's Avatar
yeah. jb weld needs lots of time. glue and leave out for a day.
Sep 13, 2014 02:59 PM
dreamtripper
Apr 29, 2008 02:49 PM
newport996
Dec 28, 2006 11:33 AM
Dock (Atlanta)
May 25, 2004 03:09 AM
