Pss9s/Pss10s - Adjusting Ride Height
Old Apr 29, 2008 | 08:38 AM
dreamtripper's Avatar
dreamtripper is infamous around these parts
Once installed, how easy is it to adjust ride height on Pss9s/10s? What's the procedure and how long does it take?
Old Apr 29, 2008 | 09:01 AM
wross996TT's Avatar
Ride height is done during install. The adjustments are for dampening (1=firm, 9=soft). You want to do alignment after changing ride height.
Old Apr 29, 2008 | 09:34 AM
is it possible to change ride height after initial install? Currently, I can go pretty low but I'm thinking if my commute changes to be more city driving in the future, I might need to adjust ride higher.
Old Apr 29, 2008 | 09:59 AM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
its easy to adjust... jack it up remove the tire use the spanner wrench to adjust the height. once you change the height you will need to get it aligned to save your tires
tim
Old Apr 29, 2008 | 10:14 AM
That's great! So basically the cost of adjusting ride height is essentially the cost of an alignment?
tim
Old Apr 29, 2008 | 10:24 AM
colorinc's Avatar
yes sir
Old Apr 29, 2008 | 02:49 PM
Thanks!
Texas1
Sep 20, 2015 09:12 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
Zmydust
Sep 10, 2015 12:31 PM
Taxthe1%
Sep 10, 2015 09:33 AM
flewis763
Sep 9, 2015 11:11 PM
