Exterior Door Pillars Sun Burned
Old Oct 13, 2020 | 01:43 AM
  #31
Mozella's Avatar
Registered PM
Mozella is infamous around these parts
Yesterday I wrapped the ratty looking B pillars on my 2013 Panamera. I ordered a 1"x5" piece of premium gloss-black vinyl wrap from Amazon; cost ten bucks.
I already had a squeegee, a heat gun, and an Olfa cutter knife on hand.
The clear-coat was worn and actually missing in some areas and the surface was rough to the touch. Perhaps the previous owner tried buffing the damage some time in the past.
I block sanded with 800 grit wet/dry and again with 2000 until the clear coat and paint were smooth.
Then I applied the vinyl using several UTube videos as a technique guide. It was easy and only took me about 20 minutes to apply, trim, and tuck the vinyl on both sides of the car.
Now it looks brand new. I don't know how long it will last, but my $10 piece of vinyl still has enough material to do the job again.
This is one of those DIY jobs that even a real hamburger might consider attempting. The material cost is very low as is the risk of damage, so if you can change a faucet washer you should be able to do this simple job. If you make a mistake, it's simple enough to start over because you'll have plenty of material. At worst, you can give up and take it a professional wrap company.
Old Oct 13, 2020 | 05:20 PM
  #32
rgfinnegan3's Avatar
rgfinnegan3 is infamous around these parts
Thanks both of you, I decided to try the eBay way first, guess retirement has made me lazy about DIY stuff...
Old Oct 18, 2020 | 02:44 PM
  #33
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
Hee is my simple DIY and low cost to fix this door pillars on my 2014 pan4.
Old Oct 19, 2020 | 04:55 PM
  #34
The eBay solution is a bit expensive, but installation is no more than 10 minutes for all 4 panels and the result is just as good as replacing the side panels.
Old Oct 24, 2020 | 06:56 PM
  #35
Originally Posted by mwvh
Same issue here. Sunburnt on right side. I bought the parts from suncoast ($80 each) and looking to install them myself.
Found this video that shows a Macan replacement, but Panamera seem more complicated.
https://www.youtube.com/watch?v=dTF7FCXEgIU
Has anyone done this themselves?
I have 2 USA-Drivers-Side brand new Panamera panels, like the pictures taken by MWVH above, for sale $150. PM me if you're interested.
Old Oct 24, 2020 | 07:43 PM
  #36
StaleBread's Avatar
5 Year Member
StaleBread is infamous around these parts
Originally Posted by rgfinnegan3
I have 4 brand new Panamera panels, like the pictures taken by MWVH above, for sale $150. PM me if you're interested.
I'm interested. Are they unblemished?
Old Oct 24, 2020 | 09:51 PM
  #37
i also bought the panel from ebay for $60. I used as a template for my my 3m 2080 wrapper. I agreed the ebay panel is thicker. I save them for next time. I have another 2016 Pan SHE, the same issue with the side. It is small peeling. i will bring it to dealer since it is still under warranty before end of dec/20.
Old Oct 25, 2020 | 12:58 PM
  #38
StaleBread's Avatar
5 Year Member
Still interested...
Old Oct 25, 2020 | 08:04 PM
  #39
Originally Posted by StaleBread
Still interested...
Sent a PM
Old Oct 5, 2021 | 07:08 PM
  #40
ddx77's Avatar
ddx77 is infamous around these parts
Those 3m ebay pieces lasted about 3 months, got worse that the original.
My next effort is going to be these I think.
https://www.rvinyl.com/Porsche-Panam...Post-Trim.html
Old Oct 5, 2021 | 08:14 PM
  #41
StaleBread's Avatar
5 Year Member
Burned B Pillar covers cont.
Mine have been on almost 8 months... they are just starting to "bubble" a tiny bit... I pressed them down again with some heat, looks OK but
I'm biting the bullet and replacing them with new OEM parts. The car is garaged so I doubt I will see that kind of degradation the originals suffered.
Old Oct 5, 2021 | 08:25 PM
  #42
ddx77's Avatar
Where did you find the oem pillars? I have bitten the bullet a few times on this car, I am tired. I am thinking I am going to need to buy replacement headlights soon too.
Old Oct 5, 2021 | 09:13 PM
  #43
StaleBread's Avatar
5 Year Member
I googled the part number and came up with a bunch of dealers that have them. The best price I found was Gaudin Porsche of Las Vegas... like $86. ea. plus shipping... sometimes you just have to spend a bit to get it right.
Expect212
Dec 31, 2021 07:31 AM
JoelPirela
Dec 17, 2011 11:26 AM
forbes210
Aug 30, 2011 12:56 PM
toothdoc
Apr 6, 2005 07:56 AM
