Proper Coolant / Antifreeze Specification: G-40-91 EF, Silicate or non-Silicate?
Old Dec 29, 2019 | 06:59 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
I keep having to add coolant now that the car has sprung a leak. Waiting for someone to get back to me about getting the car back in shape I’ve been looking for (cheaper) alternative antifreeze/coolant for our ‘13 GTS, (if the specific model matters I’m not sure). The concentrated gallon I bought from FCP Euro says Formula G-40-91 EF and Part No. 00004330575. It is pink colored. As a little background I have a rainbow of colors to choose from at home, but none of them are pink. Researching there are two pink colored alternatives: Peak OET European non-silicate enhanced and Zerex G-40 Silicate enhanced. From some searching online looks like Zerex G-40 might be the correct one. There were images of a G-40-91 EF bottle with different part number showing silicate enhancement on the back somewhere. For some reason the Peak selection guide shows OET European VIOLET colored coolant (silicate enhanced) as the proper version...
Anyone know which alternative(s) work? Thanks!
Old Dec 29, 2019 | 07:27 AM
jzchen's Avatar
5 Year Member
Found the images of the G-40-91 EF with different part # showing silicate enhancement. Ingredient list is not on my bottle...
http://986forum.com/forums/527274-post15.html
Old Dec 29, 2019 | 01:57 PM
NormalFellow's Avatar
NormalFellow is infamous around these parts
check PM's
Old Dec 29, 2019 | 01:59 PM
Oh, in your case, for the time being, assuming you arent taking anymore road trips, you can simply use distilled water
Old Dec 29, 2019 | 02:00 PM
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
Hi,
the G40 Si-OAT is the right one. => https://www.glysantin.de/en/glysantinr-g40r-concentrate
Old Dec 29, 2019 | 11:58 PM
jzchen's Avatar
5 Year Member
Thank you for the guidance.
I just don't want to be adding expensive stuff while it is leaking...
Ktw
Nov 5, 2020 07:39 PM
TexasNewfie
Jun 26, 2018 02:06 PM
scsponger31
Sep 17, 2013 07:16 AM
akim47
Jul 29, 2010 11:56 AM
motoadve
Cayenne 955/957
Aug 24, 2009 08:54 AM
