Coolant Drain, Fill, and Bleed (V8, if that Matters)
Old Oct 27, 2023 | 05:08 AM
  #31
tallpaul's Avatar
tallpaul is infamous around these parts
Originally Posted by Marc13190
I go to bleed and refill my coolant with G40 Glysantin.
It's not necessary use stop leak ?
I've contact Porsche and the coolant is for the life. What do you about this ?
There is no pre-defined replacement period on the coolant, They recommend checking the coolant every 20K miles and replacing as needed. Chances are by the time the coolant is bad you'll have a reason (water pump, leak) to change it anyway.
Old Oct 27, 2023 | 07:34 AM
  #32
Marc13190's Avatar
Marc13190 is infamous around these parts
Yes it's true but if the bad coolant water is the cause of pump problem ?
Do you think it's necessary put stop-leak ?
Old Oct 27, 2023 | 08:33 AM
  #33
tallpaul's Avatar
Yes, things that impact the coolants lubricating qualities can absolutely cause premature failure of the water pump. .But Porsche had a lot of waterpump quality issues around this time frame, so it's also possible it's just a poor design. No, stop leak is not generally required for a healthy cooling system. It's just going to mask a problem. If the problem is small, or like jzchen you need to defer a problem, it can be a great option but there should be no reason to use it proactively and it won't help stop future issues.
Old Oct 27, 2023 | 09:56 AM
  #34
Marc13190's Avatar
Thanks for your answer
anasu98
Mar 12, 2022 04:52 PM
maverick997
Feb 22, 2015 06:00 PM
karlfranz
Aug 10, 2013 07:57 AM
ant_8u
Feb 29, 2012 07:35 PM
r34dy2walk
Sep 2, 2008 08:24 PM
