Help needed regarding estimate from dealership. CPO. SE Hybrid 2014
Old Feb 5, 2020 | 11:29 AM
Maxime75us's Avatar
Maxime75us is infamous around these parts
Hi all,
dealership sent me an estimate regarding the following that needs to be changed:
ISSUE: ELECTRIC VACUUM SYSTEM CAUSING MALFUNCTION IN BRAKE VACUUM LINES CAUSING CHECK ENGINE LIGHT.
RECOMMENDATION: REPLACE ELECTRIC VACUUM PUMP, VACUUM LINES W/ CHECK VALVES, CHANGE OVER VALVE, RELAY AND FUSE.
Can someone explain me what it is and is it a difficult job to do? And why is it not covered by CPO?
Thank you All
dcarrer0
Oct 16, 2019 08:03 PM
Maxime75us
Dec 26, 2017 10:37 AM
911BOY
Nov 9, 2016 07:36 AM
rastamanPT
Cayenne 958
Nov 13, 2014 06:33 AM
frank69m
Apr 26, 2013 10:55 PM
