Differential Fluid
Old May 11, 2020 | 08:44 PM
tastefulmod's Avatar
tastefulmod is infamous around these parts
Differential Fluid
Does anyone know if the Porsche fluid is the Shell Spirax s5 or S6?
Old May 12, 2020 | 06:09 AM
tallpaul's Avatar
tallpaul is infamous around these parts
Glad you asked, I'm curious alternatives people have had good luck with. I'm due to change mine so I've been researching a little.
According to Ciaka great post it's Shell TF0591 as the dealer labeled version https://www.6speedonline.com/forums/...vice-info.html
This is how it is branded and sold. It's also sold as an ATF. While in theory most transaxle fluids can be interchanged as long as they meet GL-5 and are the correct weight (75W-90). He specifically says he used Mobil 1, which is sold as manual transmission fluid.
As for Shell Spirax S5 vs S6 - looks like the difference is S6 is designed for industrial applications, S6 is for automotive. Also, it appears S6 is GL-4 only. So based on this alone I'd suggest S5 to your original questions. The Mobil 1 fluid is also GL-5.
http://tdc.ge/wp-content/uploads/201...ATE_75W-90.pdf
http://tdc.ge/wp-content/uploads/201...GXME-75W80.pdf
https://www.shell.com/promos/lubes/b...x-brochure.pdf
Old May 12, 2020 | 10:09 AM
I called Mobil and Shell and both told me their system says its manufacture specific fluid and they don't have an equivalent. Shell actually told me their Spirax line doesn't have approval from Porsche. Since I have the base model with the open differential, they told me I shouldn't worry about putting fluid with the LS additive but not the other way around. I am almost at the point of just paying the $50 per quart at the dealer instead of trying another fluid that might cause over $100 in repairs.
Old May 12, 2020 | 11:34 AM
tallpaul's Avatar
They didn't happen to say what was specific about it, did they? Usually if there is something specific there is at least some information about what it is.
@ciaka how did your research go when deciding to go with the Mobil1 fluid? Any ill effects?
Old May 12, 2020 | 12:07 PM
ciaka's Avatar
My diff fluid and car are just fine. No adverse effects after what? Over a year?, year and a half?
Porsche will tell you to use some fluids that they charge you 100 dollars/quart for, and other folks, via chemical analysis have proven oils at 7 dollars/quart being just as good.
Porsche dealer know they have a huge revenue stream from repairs. It is up to customer to learn and make decisions about their property.
If I walk into Porsche dealer today, ask them to look over the car, despite it being in tip top shape, they would 'find' at least 10k worth of doing. Its their business, to take money from folks who are willing to give it to them.
I cross referenced the Shell oem fluid to this one via research and talking to a couple dealer mechanics. Been a while though.
Bottom line, if you are not confident 100%, pay dealer for change, or put in whatever else makes you feel 100% confident.
I am 100% confident in my choice via hours and hours of leaning and researching.
As mentioned, the fluid works great and serves my car perfect.
Old May 12, 2020 | 03:40 PM
Thanks Ciaka for the response. I always do my own work and thank you for sharing your DIYs. As for the fluid you used I cant seem to find it in local shops and am only finding the regular mobil 1 with LS. Did you have to order it?
Old May 12, 2020 | 03:48 PM
ciaka's Avatar
Just looked and I ordered the fluid on Amazon.com.
47 bucks for a gallon.
Hit online, easier to find.
Old May 13, 2020 | 05:35 AM
tallpaul's Avatar
If you can't find the Mobil-1 it does seem any GL-5 75-90 would work as well, based on Ciaka experience. Though Mobil 1 is great there are likely a number of other options available locally and online.
Old May 13, 2020 | 09:37 AM
Some more info I have gathered from Liqui Moly. If you would like to use Liqui Moly and have the open differential you will need the GL4+. If you have the limited slip differential I was advised to use the higher viscosity 75w140 as their 75w90 GL5 does not meet Porsche spec.
Old May 13, 2020 | 10:36 AM
tallpaul's Avatar
So did a little more research. According to the Porsche Service manual
I also found a @ciaka posted on another site confirming the part number:
was just able to confirm that Porsche Cayenne Turbo 2003-2006 uses same part number for gear oil.
Porsche PN for Cayenne Turbo differential oil: 000 043 205 30 - 75W90
Porsche PN for Panamera Turbo differential oil: 000 043 205 30 - 75W90
I also looked at Red Line (ran it in my EVO and loved it) and they appear to support that specific part number + the specific SAF Carbon Mod and SAF-PD the diffs need. I think this is the one I'm going to go with unless I find something more compelling.
https://stmtuned.com/products/57904-...-gl-5-gear-oil
Here is the official red line site: https://www.redlineoil.com/75w90-gl-5-gear-oil - click on OEM comparability.
Not 100% sure if that is what everyone says by "Porsche Spec" but seems pretty accurate. Looks like Castrol and a few others have SAF CArbon Mod/SAF-PD complaint 75W-90 GL5+.
@tastefulmod Surprised they recommended a 75W-140.
Old May 13, 2020 | 08:52 PM
ya there is a difference between the oil for the LS rear differential and the non LS differential (open differential). I was surprised as well that they would recommend the 75w140. He mentioned to me that if the fluid causes damage to my differential that they will cover it. I will give this fluid a try and post back in maybe 6 moths time unless things go south before then lol
TurboTodd
Cayenne 955/957
34
Feb 4, 2018 08:17 PM
viprklr
Sep 28, 2016 09:35 AM
RT7
Nov 7, 2015 09:51 AM
ciaka
Cayenne 955/957
Apr 25, 2012 02:31 PM
elduderino
Apr 25, 2005 04:18 PM
