Still getting.....Oil Pressure Monitoring Fault
Old Aug 25, 2020 | 12:22 PM
Mazurda's Avatar
Mazurda is infamous around these parts
Recently replaced oil pressure sensor after receiving the fault code intermittently while in Sports Plus mode while driving (gauge goes to 0, still showing boost, and then comes back to reading oil pressure). Oil pressure seems to go much higher than usual almost hitting 5 on the gauge when in high RPM range. Have not been able to pull a code since the light does not stay on long enough. I see many other owners have experienced these symptoms. Is the oil pump the only other step to this? Car is 2011 PTT with 64k miles
Old Aug 25, 2020 | 02:56 PM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
I've read this on another forum and on a 4S...
"There is a oil pump pressure regulating valve on the side of the oil pan that he suspects is faulty, and is fairly easy to change. If that doesn’t fix it, he said the oil pump would be the next thing on his list to check."
Old Aug 25, 2020 | 03:13 PM
Mazurda's Avatar
I read the same thing, unfortunately I can not find a part that fits that description, it seems that it cross references to the oil pressure sensor which I already replaced.
Old Sep 15, 2020 | 06:16 PM
ddx77's Avatar
ddx77 is infamous around these parts
My 2012 Panamera base (110k miles) has been doing this for about 30k miles. Already changed the sensor and had the oil pump checked. Can't find the problem, it's intermittent but only on the highway at higher speeds.
Old May 25, 2021 | 12:03 PM
Redroad's Avatar
Redroad is infamous around these parts
Did you ever got to the bottom of this? I have the same problem every time I go into the high way and pass 60 MPH. Need to know how to fix this.
Thank you!
Old Jun 3, 2021 | 09:16 AM
dArtery's Avatar
dArtery is infamous around these parts
I have the same issue intermittently with my 2012 4s Sports Mode Plus while driving.
Old Jun 4, 2021 | 01:19 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Someone with PIWIS could look up the diagnostic code if you have a reader...
Old Jul 31, 2021 | 08:26 AM
Dgbryant's Avatar
Dgbryant is infamous around these parts
130K Panamera base model experiencing same oil pressure sensor fault…
Just started experiencing this problem over the past 10k miles.
observations…
1. loss of oil sensor readings (drop to zero) and yellow fault indicator occurs on a warm engine, usually after a restart.
2. Operation of the engine during this loss of oil pressure signal seems normal. No change in engine temperatures of the water or oil during the interruption in oil pressure. No unusual sounds or rpm noticed during driving. First time this happened… I was shocked and thought I was in catastrophic failure. Soon the pressure reading returned. Whew…
3. Duration of the loss of oil pressures signal varies between less than 1 minutes to sometimes 10-20 minutes before it recovers a signal.
4. My mechanic has suggested replacing regulator first. If that does not work, replace the oil pressure pump… yikes (several thousand dollars)…
5. Please call, text, WhatsApp or email if you have solved it. I’ve’ loved my Porsche and had zero issues till now.
+1.770.597.4984 SMS or WhatsApp
dgbryant@mindspring.com
Thank you in advance
David
Old Nov 9, 2021 | 11:23 AM
Dgbryant's Avatar
Did you get it solved ? Would appreciate an update. I’m having similar issues
please update. Have you solved it ?
David
+1.770.597.4984
Mazurda;4848769
Old Nov 9, 2021 | 11:33 AM
Mazurda's Avatar
It went away after replacing sensor just not immediately, never replaced oil pump, I am currently dealing with a 6 week wait for a new differential
Old Nov 9, 2021 | 10:44 PM
ciaka's Avatar
I dontbremwmber if I had to reset with iwis after oil pressure sender replacement. Something tells me I removed battery cable for couple hours, after reset with tool to clear all errors. Some porsche sensors do keep error for aboutv50 miles after replacement. Unless cleared and power removed. I'd try just in case.
Old Nov 10, 2021 | 03:08 PM
clc3251's Avatar
5 Year Member
clc3251 is infamous around these parts
I replaced the sensor and still get the warning although much less frequently.
Old Nov 10, 2021 | 04:00 PM
ciaka's Avatar
Try to reset with a diag tool, then pull battery cable for couple hours to reset everything. Thats my only other suggestion here. From what I remember on my cayenne, I replaced the oil sensor, and error was still coming back until I reset with Durametric and removed battery cable for a while. Then it all went away and never came back.
Hope it helps you. Thanks.
Old Nov 11, 2021 | 04:48 AM
clc3251's Avatar
5 Year Member
Reset all codes and disconnected the battery for 2 days whileI did the front struts. Still get the warning although now just occasionally.
Old Dec 2, 2021 | 11:20 PM
ciaka's Avatar
I'm sure you are probably aware. But if your replacement oil ressure sensor is not a genuine Porsche part, it's very likely to be throwing a code. Many who did this learned the hard way.
parts often sold as oem, but that dies not mean they are genuine Porsche. Must be genuine porsche part (identical to what is installed at factory).
