Piwis 2 tester - location to recode battery
Old Sep 21, 2020 | 08:37 PM
ciaka's Avatar
Anyone here have or used PIWIS 2 tester, to recode battery when replaced? Where in the PIWIS 2 software is the option to do this? Diagnostics? I have searched but could not locate.
Thanks.
Old Sep 21, 2020 | 10:23 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
This guy seems to have the document:
https://rennlist.com/forums/991/9904...l#post14187199
Maintenance > Repair > Battery Replacement
Old Sep 21, 2020 | 10:47 PM
ciaka's Avatar
Thanks. Too bad it's late, or I would be cranking open the piwus2 with the car, to do now. Guess waiting til tomorrow.
Old Sep 21, 2020 | 10:54 PM
jzchen's Avatar
5 Year Member
I had to search up how, but I just saw your question maybe 30 mins ago and have been searching since. I didn't download the instructions sadly and YouTube videos show aftermarket tools...
Old Sep 25, 2020 | 03:42 AM
sunnyc123abc's Avatar
sunnyc123abc is infamous around these parts
It’s under Gateway / Maintenance repairs
Old Oct 4, 2020 | 02:20 AM
ciaka's Avatar
Yes, checked today. Battery decode is under gateway/repairs. However when I change the values to 95Ah, any batt name, make up serial, make up part number, and press F8 to save, it tells me values are saved, but when I exit, then return, read out shows same old values still there, my entries not saved. Am I doing something wrong here?
Old Oct 4, 2020 | 10:45 AM
jzchen's Avatar
5 Year Member
No wonder I had a hard time with the Foxwell tool, even PIWIS has trouble...
I guess the computer is finicky with formatting.
Does it give you the # of characters you need to enter for part # and serial #?
I can't remember off the top of my head and video took too much Google drive space it may be deleted...
Try using the same manufacturer as original
Enter the part # with the "." so 11 characters.
Enter serial number as 10 characters I believe. Crossing fingers for you...
Old Oct 5, 2020 | 05:41 AM
Mozella's Avatar
Registered PM
Mozella is infamous around these parts
I installed a Diehard AGM battery yesterday and registered it using my iCarsoft Scanner POR V2.0
I selected 95ah AGM for the capacity.
The scanner listed several brands, but not the Diehard, so I selected "Reserved 1"
The serial number entered just fine using the number shown on the battery, 10 characters as I recall.
The part number I got from the Internet by doing a Google Search on "Panamera Battery". One of the sources selling genuine Porsche batteries listed the part number. I used that info and it input OK without issues.
While entering the data, I was careful to match the upper/lower case letters when appropriate.
Everything "took" OK and as far as I can tell, I'm good to go. No sparks, no fires, and no explosions so far.
Old Oct 5, 2020 | 01:54 PM
ciaka's Avatar
Followed examples for serial and part number. Used varta for vendor. F8 to save, confirmed success, but checked again to see values unchanged. Again. Hmmm. Not sure what to do next.
Havent used reserved mfg yet. Next step I guess.
Old Oct 5, 2020 | 02:04 PM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Have you tried simply changing the serial number by incrementing 1 digit to see if it saves? That should confirm whether your tool is at least saving a valid entry.
Old Oct 5, 2020 | 03:49 PM
ciaka's Avatar
When I read the data, it only reported vendor and Ah rating. Serial and part number fields were blank.
Old Oct 5, 2020 | 05:18 PM
Nikita4Ever's Avatar
Nikita4Ever is infamous around these parts
I have the Durametric tool. Can it reset the battery?
Old Oct 5, 2020 | 11:17 PM
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Unfortunately, Durametric can’t recode for new battery. For Panamera, Durametric is good for resetting service minder and reading fault codes. I just sold my Durametric Pro cable for this reason now that I got a PIWIS 2.
I’m watching this thread carefully as I will likely need a new battery (mine is going on 6 years).
Old Oct 6, 2020 | 06:39 AM
jzchen's Avatar
5 Year Member
That doesn't sound good. Should read properly, did it read your VIN correctly? Sounds like you should contact the PIWIS vendor at this point...
Old Oct 7, 2020 | 03:02 AM
So messages I’m going to get if I put in a new battery without resetting it?
