Driver seat memory adjustment won't work
Intermittently, it happen on and off. I noticed sometimes, I step in the car, turn the ignition on, and the driver seat wont adjust to my position? This happen on and off, usually it does adjust fine. Not sure what it trigger it not to adjust? Does any one experience same issue? I end up pushing the memory button to move it. Thoughts?
The other possibility is if you are using two different key fobs - the key fob saves the settings too I believe so that, hypothetically, when two different people use the car, the car (seats etc.) adjust to whomever gets in using their unique FOB.
Thx SJ-Panamera. I'm the only one driving it. My wife doesn't like the car. I will watch out for the battery notification service, as this may be the reason. Any idea when should I consider battery change? I just received Icarsoft por 2.0 and I will check out the battery using it and see how much power it has. The battery is giving me 11.9 V after 2 days not driving it.
It keep happening over and over. What I noticed since I'm driving this car on a daily bases that, If I stepped out of the car, for a short time and locked it, to get something from a store very quick. Once I come back and start the car, the seat won't move back to my favorite position. I have to press down the memory button at the door. However the seat memory work fine, if I steeped out of the car for long time more than hour or so. Once I come back the seats moves fine!
