2011 Panamera 4S rear suspension stuck in high mode
Old Jan 25, 2022 | 08:58 PM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
After the cold spell here in alberta my rear end went into off road position. How do I lower it back to normal? I read that some have bled the rear shocks but I don’t know how to do that. Can anyone chime in?
Old Jan 26, 2022 | 08:41 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
Check the 40amp fuse for the air suspension compressor. If it has blown, the suspension may be stuck in a high position mode.
I had this happen a couple of years ago after driving in lots of rain and then having it get cold very fast. The compressor had some moisture condensation in it and was not able to start --- blew the fuse and suspension raised to a "defaults failed" position.
May be a good reason for the initial "nitrogen fill" of the suspension system.
Good luck,
Old Feb 4, 2022 | 11:32 AM
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
Good luck,
This. i've had a few faults in my air system, and each time it was the 40 amp fuse that blew. it's in the trunk next to the battery. For some reason it happens to me only when it's in cold temperatures.
carvingcanyons
Sep 2, 2017 02:45 PM
M3putt
Mar 10, 2016 05:18 PM
NDP23
Apr 13, 2012 08:35 AM
dallascajun
Jul 10, 2010 10:57 PM
