Torque specs for front end parts - FYI?
Old Feb 3, 2022 | 05:05 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Front end torque specs for a 2012 S:
Lower trailing arm to wheel bearing housing: Tightening torque 130 Nm (96 ftlb.)
Upper trailing arm to wheel bearing housing: Tightening torque 85 Nm (63 ftlb.)
Tie rod to wheel bearing housing: Tightening torque 85 Nm (63 ftlb.)
Spring strut to lower trailing arm: Tightening torque 90 Nm (67 ftlb.) +120°
Drive shaft to differential: Tightening torque 22 Nm (16 ftlb.) +90°
Air guide to lower trailing arm: Tightening torque 10 Nm (7.5 ftlb.)
Brake disc to wheel hub: Tightening torque 10 Nm (7.5 ftlb.)
Brake caliper to wheel bearing housing: Tightening torque 140 Nm (104 ftlb.)
Cable holder to wheel bearing housing: Tightening torque 10 Nm (7.5 ftlb.)
Upper strut to body: 34 fl lbs
Lower strut to LCA: 67 ft lbs +120
UCA arm bolts to body in wheel well - 37 ft lbs + 120˚
UCA arm ball joint bolt to spindle - 63 ft lbs
LCA to spindle: 96 ft lbs
LCA lock nuts at cradle: 52 ft lbs
Caliper to spindle: 104 ft lbs
Swaybar end links to swaybar: 74 ft lbs
Swaybar end links to strut: 30 ft lbs +90
Eggman
Nov 23, 2012 08:07 PM
12GtR-BE
Tech / How To
Aug 28, 2011 08:04 PM
Valley996TT
Feb 19, 2011 06:40 PM
mountainC4
Feb 3, 2007 03:13 PM
dtmarsh
Jan 4, 2007 10:05 PM
