FVD Brombacher | Part Focus | 970 Turbo and 970 Turbo S | FVD Billet Diverter Valve
Old May 9, 2022 | 11:34 AM
Rhonda@FVD's Avatar
Premium Sponsor
Rhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond repute
The FVD Diverter Valve is a German made direct replacement for the OEM diaphragmed valve or for poor quality aftermarket ones that leak, causing boost fluctuations. Our valve is a piston type valve that we insist on having reinforced at the vacuum port and on the piston seal. Our reinforced valve will prevent boost leaks and will recover more quickly for better boost and throttle response.
Features:
Piston Type Diverter Valve
Precision Machined and Manufactured in Germany
Reinforced and Polished Piston
Machined Aluminum Body
High Pressure Tested Vacuum Port
Angled and Rotatable Vacuum Port for Simple Installation
Valve is Shipped with 15-25 PSI (1-1.7 Bar) Spring
Includes Clamps and Ties
Why replace the OEM Diverter valve with an FVD Diverter Valve? Under higher boost pressures associated with a tuned car, the OEM valve can start to leak via the rubber diaphragm. Also, we have seen instances where the plastic cover can lift off the sealing face as the internal spring's resistance is exceeded. This causes boost fluctuations and boost pressure loss.
The FVD diverter valve is precision machined of billet aluminum in Germany. It includes a high pressure reinforced vacuum port manufactured in Germany. We also have the piston seal reinforced via a stepped 5 to 10 mm O-ring so that pressure loss is completely ruled out.
Sold individually. 2 are required.
FVD Billet Diverter Valve | Part # FVD 123 212 | Details…
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Old May 18, 2022 | 05:02 AM
Turbovolt's Avatar
Turbovolt is infamous around these parts
Hello, can you tell me where this boost valve is located, thank you.
Old May 18, 2022 | 09:08 AM
Rhonda@FVD's Avatar
Premium Sponsor
They are located in the front bumper behind the intercoolers and can be accessed through the front fender liner. I have sent you a pm.
Rhonda Roxburgh
+1-954-571-2050 x 1
Old May 18, 2022 | 11:51 AM
Turbovolt's Avatar
Ok thank you
sideWays_swe
May 24, 2009 08:32 AM
rmrmd1956
Apr 16, 2006 11:16 AM
TDY
Dec 13, 2003 08:44 AM
