2011 Panamera DRL issue
Old Aug 30, 2022 | 03:11 PM
descarl's Avatar
descarl is infamous around these parts
Hi all
I have a 2011 Panamera Diesel and I absolutely love it. For some reason the drivers side DRL has stopped working. Everything else on the unit (indicator etc) works as expected but the LED DRL stopped working. As it's made up of multiple LEDs I don't think it's a bulb that has gone and I can't work out if it has it's own fuse so I was hoping someone could offer some advice before I have to remove the front bumper to try and check the wiring etc.
Any help or advice would be greatly appreciated as it's starting to irritate me :-)
Carl
Old Sep 6, 2022 | 01:22 AM
fullmetaljacket's Avatar
fullmetaljacket is infamous around these parts
If you have a non turbo Pan and your DRL is consolidated with the turn signal and park light assembly mounted on the bumper which looks exactly like this...
DRL, Turn Signal Lights and Park Lights in one assembly mounted on the bumper. Non Turbo Pan S 970.
Then the unfortunate answer is NO, you cannot repair or replace the bulbs becasue the LED bulbs are really unique. If you look closely at your assembly, concentrate on the lower half of the lens, try to look up on the lens divider and you will see the LED bulbs that are really unique.
Here's the part number so you can order from Pelican or get from ebay...97063108202 replacement part 97063108204
Here are some links of my previous posts that can help you further...
ORIGINAL THREAD ON DRL which has some useful information on how to take out the assembly without pulling down your whole bumper and I also provided a wiring diagram with pictures so that you know how you can conduct some tests with the electrical wiring...
https://www.6speedonline.com/forums/...ng-lights.html
THREAD ON UPGRADING TO LED TURN SIGNAL BULBS (just in case you're up to it)...
https://www.6speedonline.com/forums/...imple-mod.html
Hope all of this helps you.
Yoghurtshotgun
Bentley
Jun 1, 2025 03:47 PM
Dr.Disaster
Bentley
Nov 11, 2015 08:21 AM
Panamera Vendor Classifieds
Oct 28, 2013 03:26 PM
ysfg35
Sep 9, 2011 08:49 PM
MarkP
Feb 20, 2011 09:52 PM
