Blending Door Actuator Replacement
Old Oct 30, 2025 | 06:37 PM
drawblood's Avatar
drawblood
Hello fellow Porsche enthusiasts. I have a '12 Turbo and wondering anyone has replaced their blending door actuator?
I'm blowing hot air on the driver side, and freezing cold on the passenger side. I hear a buzz from behind the stereo, so I'm assuming the actuating motor is stuck or no longer operational?
Is the motor located behind the head unit?
Can someone point me toward directions?
Thank you!
Old Oct 31, 2025 | 07:01 PM
Genejr76's Avatar
Genejr76
I'm very much aware the Porsche Cayenne (the 2012 Turbo is a 958 generation), there isn't just one actuator; there are several. However, the one responsible for the left/right temperature difference is typically located deep within the dashboard, behind the climate control unit and potentially the head unit area.
It's a tight fit and generally considered a labor-intensive job because you have to remove a good portion of the center console and sometimes other trim to access the screw holding the motor in place.
Old Nov 6, 2025 | 08:57 PM
drawblood's Avatar
drawblood
Thanks for the reply. I'm surprised I haven't found anything online.
I'm going to take the head unit and center column out to see if I can find the motors. If successful, it'll make for a good DIY write up
Old Nov 8, 2025 | 04:57 PM
Genejr76's Avatar
Genejr76
You are welcome friend. Good luck with you.
W. M. Hellinger
Bentley
Jan 15, 2023 05:18 AM
rich9911
Bentley
Apr 10, 2020 08:38 AM
Willard13
Jan 25, 2018 03:30 PM
APerez
Aug 10, 2016 07:23 PM
2001Porsche911
Apr 29, 2015 07:21 PM
