JRZ Suspension Sale
Old 06-24-2010, 11:15 AM
TopSpeedInc's Avatar
TopSpeedInc is on a distinguished road
JRZ Suspension Sale
Price: $0
Private or Vendor Listing: Vendor Listing
Part fits: Porsche 911 997 Turbo, Porsche 911 997 Non-Turbo, Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo, Porsche Boxter/Cayman, Older Porsche, Ferrari, Nissan GTR
Location (State): GA
Item Condition: Brand New
JRZ Suspension Sale
Thanks to a fantastic relationship with JRZ we have been given the go ahead to pass on some great deals to our customers on JRZ Suspension Kits.
Our JRZ kits are shipped with everything you need to install them
Here is whats included in our kits
Dampers, Front Camber Plates, Rear Top Plates, Main Springs, Tender Springs, Aluminum Spacers, Rear Anti Roll Bar Brackets, Front Anti Roll Bar Bracket(if Necessary), Quick Disconnect Fittings for Remote Reservoirs (If Necessary)
Clubsport
The new RS and RS Pro line is developed for the serious club racer and high performance street application. Bred from our winning racing dampers, the adjustment systems of the new RS and RS Pro line, are based upon the same technology as the JRZ race dampers. The new RS and RS Pro line is a high-end damper, at an affordable price. The RS and RS Pro are double adjustable with separate rebound and compression adjusters. Dependable and easy to work with, this system will allow you to use a wide range of spring rates and eliminate the worry of having to constantly re-valve every time you want to increase or decrease your spring rate. They do not require constant maintenance to ensure they work properly - you can put them on and drive! They are made with the highest quality materials and workmanship available.
RS MSRP Starting at $$4745
The JRZ RS is a high end street damper with is suitable for club racing as well. The RS is based on the twin tube design. This feature makes the damper two way adjustable, without the need of a remote canister. The absence of a canister makes mounting very easy.
RS PRO MSRP Starting at $5505
The JRZ RS Pro is a canister damper. The design is based on the RS, but the canister makes an even wider adjusting range possible. The JRZ RS Pro is the solution for the pro club racer.
JRZ Racing
The JRZ Racing dampers are used by race teams all over the world competing in race classes ranging from Asian GT to Rolex series, Formula 3 to IRL.
The JRZ Racing product range contains single, double, triple and quadruple adjustable dampers.
Double Adjustable MSRP Starting at $6380
The double adjustable damper is adjustable in both rebound and compression. In addition to the same precise and accurate rebound adjustment mechanism as in the single adjustable, the double adjustable damper has a remote reservoir with the compression adjuster and gas volume. This reservoir is connected to the damper with a Teflon-lined high-pressure hose. With the 22 mm diameter pistonrod, a large volume of oil is displaced by even the smallest movements of the suspension This translates into a very precise and sensitive compression adjustment, necessary for a race car.
Triple Adjustable MSRP Starting at $7860
The triple-adjustable damper has a separate adjustment device to control the low speed compression damping forces without affecting the mid- and high-speed range. Because the large 22mm piston rod provides sufficient oil flow on very small and low-speed damper movements, the low-speed adjuster mechanism is very sensitive and responsive The low-speed adjuster uses a bore design in which the area can be varied. The adjuster is located on top of the remote reservoir and has eight adjustment positions. Changes made to low-speed damping forces (damper rod velocity of less than 1.5 – 2 inches per sec.) have a major effect on handling because corner entry, corner exit, braking, and power down are all about low speed piston rod movements.
4-way Adjustable MSRP Starting at $13590
The high-end 4-way adjustable damper is the top in the JRZ product line. The main philosophy behind the 4-way is the fact that low speed piston movement influences the roll and pitch characteristics of the cars handling. The high speed piston speeds occur when driving over bumps and curbs. The 4-way adjustable damper makes it possible to tune the cars behavior independently in all situations.
Call or PM for pricing on your custom setup
Installation and Setup as well as track side support available
[IMG]http://i848.photobucket.com/albums/ab43/CicioTopSpeed/Graphics/LucyForumBanner.jpg[/IMG
TopSpeed Inc.
Matt
678-297-7770
Matt@TopSpeedTuned.com
Old 06-25-2010, 06:58 AM
Thanks for the order Chris and Jim.
Sorry if it takes a little while to get back to everyone who has messaged me. Its very time consuming to spec out each persons custom package, Ill get back with you as quickly as I can.
Matt
Old 06-28-2010, 07:10 AM
Thanks for the order Evan
Old 06-28-2010, 10:00 AM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
please pm me pricing on RS Pro's
Old 06-28-2010, 01:08 PM
email sent
Old 06-30-2010, 06:50 AM
Thanks for the orders 6speedonline
Old 07-12-2010, 02:06 PM
Buy a set and then come out to our private test day at Roebling Road for a little help from Bryan at JRZ dialing them in.
Old 08-12-2010, 08:14 AM
Running some awesome specials on JRZs right now. Give us a call or PM for more info.
Old 08-20-2010, 10:18 AM
Afternoon Bump
Old 09-15-2010, 08:34 AM
Morning Bump
Old 09-22-2010, 09:31 AM
Wednesday Bump
Old 09-27-2010, 12:00 PM
Cicio@TSM's Avatar
Cicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant futureCicio@TSM has a brilliant future
We really appreciate the business and support from the community guys!
~Cicio
cicio@topspeedmotorsports.com
www.topspeedmotorsports.com
-FASTEST 991 Turbo in the WORLD: 201.97 MPH
-HIGHEST HP 991 in the WORLD: 1287whp
-991 Turbo S Build Thread
-COBB ProTuner
-Syvecs Dealer / Tuner
-Complete in House Builds
Old 10-05-2010, 07:50 AM
Go Faster with TopSpeed and JRZ.
Old 10-12-2010, 09:07 AM
Bump Page
Old 10-15-2010, 08:33 AM
Bump for JRZ
Quick Reply: JRZ Suspension Sale
