FS: 19" Forgestar CF10 - see photos
Category: Wheels & Tires
Price: $1125
Part fits: Porsche 911 997 Non-Turbo, Porsche 911 996 Turbo
Location (State): CA
Selling my Forgestar CF10 wheels to make room for a new style of wheels.
These wheels have very very little mileage bc I haven't had much time to drive the car and the wheels have no curb rash.
Sizes:
9x19 ET 47mm semi concave
12x19 ET 41mm concave
Rear has a very tiny rub on the inside fender liner under heavy max compression but my car is slammed and anyway this almost never happens, and it is also connected to my aggressive negative rear camber setting. A 3-5mm spacer or less crazy camber can probably fix that.
Other members use the OEM 997 Turbo tire sizes on the exact same wheel width and final offset, those tires are slightly smaller.
I used 997 GT3 sizes for tires which are bigger but still within the 5% tolerance for the 4WD differential on 996TT.
My tire choice was Hankook Ventus RS3 235/35/19 and 305/30/19 which are pretty wide for the numbers and have very square outer blocks (tire shoulders). Most other brands are more rounded on the shoulder so they give even more clearance.
Price includes wheels (no rubber) with center caps and hubcentric rings.
Shipping: They are packaged in proper wheel boxes and can be shipped within the US at buyer's expense.
The offset difference to a 997 is that these front wheels will sit 7mm further out and fill anoter 1/4in on top of that due to being a wider wheel, total basically 13mm further out than stock 997 turbo wheels. You'd have to check the 997 section if that will work.
These rear wheels will sit 10mm further out plus the wheel is 1in wider than stock 997 turbo wheels, so total outer edge will be 22.6mm further out. Again, check the 997 section if that will work.
