Modified M3 For Sale
Old Dec 23, 2011 | 07:15 AM
MiniDHinkle's Avatar
Year: 1998
Make: BMW
Model: M3
Price: $11500
Mileage: 153000
Color: Black
Location (State): TN
Transmission: Manual
Drivetrain: Rear Wheel Drive
FS or FT - 1998 BMW M3 Tastefully modified and maintained
$11, 500 FIRM (Will include a set of LTW's and pro detail)
This isn't your typical "moded bro" M3. It's an enthusiast' built car, owned by purists.
The modifications are tasteful, and very expensive. This car is absolutely incredible, but I've always wanted a ZHP. So, that's what I'm going to buy.
The modification and spec list (*note, I do have a binder full of receipts including the original window sticker and documents from the original owner - not all service records and modifications are found from previous owners but many are).
1998 Cosmos Black M3 - On Black with power vaders.
151k Miles
The modification list:
HK stereo system, 6CD changer, Vader power/heated seats, stock spoiler, alarm/keyless entry, 6 spd
Getrag EVO 6 Speed transmission with SSK, UUC delrin shifter bushings
Sachs Clutch with DM Luk Flywheel
UUC Clutch pedal bushings
3.46 40% Lockup Diff
DEPO headlights with city lights and 55watt HID’s on low beams
Coolant system: BEHR radiator, t-stat, w/p, hoses, evap can, sensor, alum housing
RTAB: Powerflex, LCAB: Rogue Engineering, Rear Subframe: Powerflex
Dr. Vanos Stage 1
New valve cover gasket
NGK plugs, coil pack boots
Malhe Fuel filter
Bosch 80 Amp alternator
OPN checked, OEM oil pan gasket
F*A*G front wheel bearings, Meyle front/rear sway links
Re-manufactured steering rack with Meyle tie rod assemblies
F*A*G rear wheel bearings, Meyle control arm bushings, Meyle outer ball joints
UUC rear adjustable control arms
Bilstein Sport shocks, GC Camber/caster plates front, RE rear shock mounts, H&R Sport Springs
Lemfordor upper front shock mounts with reinforcement plates
ZHP 6spd shift ****
Alcantara shift boot and e-brake boot
New belts, idler pullies, tensioners
JTD underpanel
OEM engine mounts
OEM sway bar bushings
UUC red trans mounts
OEM lower chain tensioner
OEM heater valve
OEM front fender liners
4 Bosch oxygen sensors
Rebuilt calipers, Zimmerman coated blanks, UUC Brake lines, Jurid pads
ATE brake master cylinder
OEM exhaust hangers
CDM
18”x8.5” BBS RK’s ET38
Vorshlag 60mm wheel stud kit
EuroSport M50 Manifold kit
OEM front lower control arms
ZF PS reservoir
X brace
Condenser cooling fan with relays
B&B Cat-back Exhaust
AFE Cold air intake with K&N Filter
OEM BMW Alpine Alarm/Keyless Entry
C43 Radio PTY
BSW Stage 1 Speakers
Black suede headliner, sunroof shuttle, a and c pillars
DEPO Smoked Corners
DEPO Clear Tails
DEPO Clear Sides
Highlights include a real, yes real, EVO 6 speed, 3.46 diff, and absolutely mint 18x8.5 BBS RK's.
Service history - these are most of the documents from my service records (*note, previous owner claimed to have spent over $30k in modifications and maintenance.)
1-6-11 Alignment, check pressure, steering linkage, suspension components 109.95
*Included camber, toe set-up (Was very aggressive when bought, I re-did alignment when I bought the car last month).
11-6-10 4 General EXCLAIM UHP tires - 429
*I bought 2 brand new ones a month ago. One is out-of-round. I have a new one replaced under warranty waiting to be put on. Bought from Tirerack.
8-26-10 Alignment
10-11-10
Cabin Air Filter
Spark Plug
Swivel joint
Belt 5K X 906
Fuel Filter
Bushing
Sway Bar End Link
Nut
9-30-07
5 Lug 60mm Long stud, 17mm Nut (Chrome) Wheel Stud Kit 73.20 - Vorshlag Motorsports
12-14-10
Ground Control Camber Plates - 299.00
No date - Dents and Dings
RT Fender Broken Paint
Repair dents on whole car - 300.00
IRP
PBR - Axxis Ultimate REAR Brake Pad Set - 34.00
1-19-07
Rotors
Pollen Filter
Pads
1-19-07
Bimmerzone
Spark Plug (6)
Spark Plug Connector
*When my CEL came on, for the loose plug, my tech went on how they were very good quality (NGK) and were in great condition. He also made sure to tighten them.
Bimmerzone
8-25-10
3 Red Line 75w90 Gear Oil
1 Pack of 8 M3 Oil Filters
2 Replacement BMW hood emblems
123.70
5-16-2007
Rogue Engineering
RSM Shock Mounts
104.38
Rogue Engeering
8-5-10
RE FCAB E36 Centered
CNC 6061 Aluminum
Urethane Insert
242.23
Private Sale-
Bilstien Sport Shocks and Struts
607.00
Zgmunt Motors 1-19-07
Valve Cover Basket
Oil Drain Plug
Crankcase Gasket Set
Oil Dipstick Seal
Brake Disk Screw set
Wiper Blade Insert
Air Filter
131.60
Summit 1-22-07
2 75W90 Gear Oil
2 Gear oil synchromax 1 QT
Multi Use Transmission Pump
57.50
Zgument Motors 6-04-07
2 Wheel Hub
2 Wheel Hub nut
Dust Shield
Muffler Hanger
187.00
UUC 6-23-2010
Chromoly Adjustable Rear Control Arms
349.00
Pelican Parts
2-22-07
1 Intake Boot
2 Rubber mount
2 Exhaust Hanger
1-22-07
Aluminum Washer
Chain Tensioner
Oil Pump Socket Nut
Clip
Antifreeze
1-18-08
Fork Lever Spring
Exhaust Manifold Gasket
Seal
Pilot Bearing
Clutch Master Cylinder
Gasket Ring
Clutch Slave Cylinder
Reservoir
Multi Purpose Relay
Temperature Switch
Brake Disc (2)
11-07-10
Turn Signal Light
Adjusting Pulley
Deflection Pulley
2-13-07
Belt 6k x1555
Belt 5k x906
Drive Belt Tensioner
Protection Cap
Idler Pully
Adjusting Pulley
Repair Kit
Guide Bushing Repair Kit
Repair Kit
Brake Shoe Set
Repair Kit
4-09-07
Strap
Secure Plate
13.20
4-2-07
Hex Bolt
Water Valve
Seal Ring
M3 Absorber
Washer
18.30
6-16-08
Bulb Socket
Sunshade
53.67
6-2-07
Collar
7.32
7-18-2007
Support
Clip M Tech
Grommet
Nut Euro
Bolt
Rubber Mount
30.26
Hendrick BMW
8-27-07
O Ring
Seal Ring
Pulse Generator
84.58
Tischer
Place
Dust Protect
Nut M12x1.5
REL LEVER
SEAL RING
BALL PIN
PIN
RIPE
REPAIR KIT BEARING
ROD JOINT
UNIV JOINT
HEX NUT
SUSPENSION
CIRCLIP
WASHER
NUT
SUPPORT
BUL WITH SOCKET
WISHBONE
RUBBER STRIP
DRV SHAFT INTERM
SPECIAL PLATE
607.50
11-03-09
Push Button
Cover
49.84
9-24-09
Expanding Rivet
Support LIfting Plate
Hex Nut
Gasket
Cover
170.74
11-11-09
E46 M3 SSK
Gear Shift ****
Suspension
Shift Lever
Securing Clip
Spring Nut
123.97
1-05-10
Hex Bolt
Fillister Head SCRE
Ball Pin
31.75
12-16-09
Compression Spring
Gear Position
Thrust Pin
120.54
3-1-10
Rubber Seal
Grooved Ball Bearing
Set of Profile Gasket
84.88
Tischer BMW
Lock Ring
Hexagon Screw
4 Rubber Mounting
Ball Joint
O ring
Clamp 2
511.82
5-11-10
Spring
Protection Plate
Cover
Covering Left
Covering Right
Protection Plate RI
CLAMP
Covering Right
Trunk Lid Gasket
163.38
BMWparts.com
9-27-10
Blind Plug (8)
Covering Left
Covering Right
Hose Clamp
103.61
11-11-10
Ashtray Rear
Covering Left
Covering Right
Bulb Socket
Covering Front Left
Covering Front Right
102.32
Hendrick
3-01-11
Collar Nut
35.38
Tischer
Support Lifting Plate
53.08
What I've done-
(2) Front Tires (General's)
Alignment
New OEM Nose
Black Grills
Coolant Change
Spark Plugs Tightened
Replace Piece under Gear Shifter
Replaced radiator and all radiator components ($400+)
Tranny Mounts (UUC were POS)
Full disclosure:
The drivers-side vader has a small rip.
The car is black. The car is a sports car. The car is also aging. Therefore, it has many rock chips. If I had to change one thing, it'd be the front bumper. The bumper is rock chipped and sags. Typical E36 problem.
I wasn't paying attention and rolled into a car at a stop light. I went ahead and replaced the nose with an OEM nose and had it sprayed Cosmos by a top shop in my area. It came out absolutely top-notch.
The previous owner had a paint-less dent removal on the right rear quarter panel. You can tell from certain angles, but I never notice it.
The paint is in decent condition for an older car. It needs a buff, and has the wear of a 98' black car, but it cleans up well.
The carfax is CLEAN - But, we found the passanger quarter panel, as well as hood, were replaced with OEM BMW DOT replacements. They match up perfectly.
Onto the pictures-
Old Dec 23, 2011 | 08:12 AM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
clean example of an e36 m3, glws
Old Dec 23, 2011 | 08:27 AM
ehummelman's Avatar
ehummelman is infamous around these parts
sent you a PM, potentially very interested pending the wife's opinion. It would be hers, and I am NOT the boss! LOL
Old Dec 23, 2011 | 09:02 AM
Replied, man!
Old Dec 23, 2011 | 10:54 AM
Bolt-OnM3's Avatar
Bolt-OnM3 is infamous around these parts
My car has allot of the same mods and then some. Good price.
Old Dec 24, 2011 | 07:03 AM
Thanks!
Old Dec 27, 2011 | 09:18 AM
Ttt..
Old Jan 2, 2012 | 08:05 AM
Bump..
Old Jan 2, 2012 | 03:19 PM
Cscat's Avatar
Cscat is a glorious beacon of lightCscat is a glorious beacon of lightCscat is a glorious beacon of lightCscat is a glorious beacon of lightCscat is a glorious beacon of lightCscat is a glorious beacon of light
As someone who knows these cars inside and out, I can say that all of the proper service has been done (if everything in the ad is correct), and the parts added are of good quality. If mine was in this nice of shape, I'd be a happy guy. Good luck with your sale. I'd kill for that 6-speed, the conversion is a few grand in parts alone.
Sales@RSW
Sep 3, 2015 09:34 AM
The Oss
Aug 24, 2015 08:19 PM
Glasig
Aug 23, 2015 03:35 PM
vbb
Aug 21, 2015 10:17 PM
