1994 Mazda RX-7, widebody, LS7, T56, 8.8", 565rwhp, Racelogic TC, more.....
Old Oct 12, 2015 | 08:02 PM
gnx7's Avatar
gnx7 has a spectacular aura aboutgnx7 has a spectacular aura aboutgnx7 has a spectacular aura about
Year: 1994
Make: Mazda
Model: RX-7
Price: $34000
Mileage: 5000
Color: Montego Blue
Location (State): CA
Transmission: Manual
Drivetrain: Rear Wheel Drive
My good friend Rich has owned this car for many a years... It was originally another Rich's car who was in California also and built it. It started out as as a stock bodied FD and LS6/stock rear diff/AP 13" brakes, and freshly rebuilt T56 and was a Cali BAR'd machine. It evolved into a freshly painted Montego blue widebody car with Pettit rear flares/bumper, Ronin front flared fenders, M2 racing vented CF hood with AeroCatch latches, and a healthy wet sump 427ci LS7 running a Cobra 8.8" IRS out back with Forgeline wheels. The cars focus has always been a streetable track Gudzira!
The goods:
1994 Touring model FD factory Montego blue color. This has the preferred interior plastics.... the ones that don't crack when you look at them.
427ci LS7 block, stock LS7 crank with the snout cut down, Ls7 Ti rods, wiseco 11.25:1 pistons, wcch ported LS7 heads with Ti 2.2" valves, ported LS7 intake with 56# ZR1 injectors, LG Motorsports G5x3 cam, Holley cable 90mm TB,
GZ Motorsports vacuum pump (helps keep ring seal optimal and blow by to a minimal)
JTR 1 7/8" long tubes, 3.5" Magnaflow s/s polished muffler. Fbody oil pan, Improved Racing baffle, oil cooler with approx 5K miles on it.
Made 565rwhp/505rwtq on Newtech Motorsports dyno 91 octane.
Turn One p/s pump, a/c in place, battery located in the rear bins, stereo upgraded with better speakers, Kenwood 640w amp/JL Audio 6" mini box subwoofer.
AP Racing 13" 4 piston brakes front, 12.9" '99 RZ rears, s/s brake lines. ABS intact and working. This car stops!
Rebuilt Stg2 T56 transmission approx 15K miles. Monster stageV single disc clutch. Shifts very tight....no slop or issues.
8.8" Cobra diff with 3.73 gears, DSS axles, 3.5" alum driveshaft. No unusual gear whine like some have.
Samberg mounting equipment/radiator and cooling components
Recovered FD seats with fresh leather/suede. Rare glass sunroof.
Racelogic Traction adj Control. Stock engine PCM with HPTuners tune for 91 octane
black interior, RaceShop chromoly roll bar, RCI 5pt quick release seat belts, Accusump, hard mounted removable fire extinguisher. Momo Corse 300mm steering wheel
Forgeline 18x11 315 R888 fronts, 18x12.5 335 RA1 rear
All poly bushings/rear pillowballs replaced, Megan racing coilovers
TriPoint Engineering adj hollow modular front sway bar/billet mounts
Freshly repainted as of 9/25/2015 bumper, hood, front fenders, rear flared fenders. The car looks awesome once again!
Front bumper and fenders have s/s mesh in them. Very nicely done and riveted firmly in place. Rear fenders riveted on for easy servicing.
100% rust free..... as in not even a spec. Clean CA title.
Flaws:
small crack in paint above fuel door, some minor rock chips on passenger door, rear hatch had an R1 wing and holes have been closed up with plugs. The small plastic cover for the trunk/gas tank release is tan.... and has been painted... its scuffed.
Accusump pukes a little by the valve.... Not a big deal as per Accusump.
Cold start until it reaches 110* water temp needs some throttle input. Once warmed up its all good. ***Just retuned last week.... issue resolved***
A couple minor dings near fuel door will be removed by a ding repair guy. Tires are old and for track duty are not optimal. Either replace or learn the car with them on. The car has an aggressive alignment for handling. This can be mellowed if preferred but will adversely affect handling.
The big question is why is Rich liquidating his stable? A 2010 ZR1 is calling his name... And there you have it. He works crazy hours and has no time to post/manage this ad. I've known him personally for over 15 years.
Rich has been a member of the original v8rx7, torquecentral, and now the current norotors.com forum. Dude.... we are old
He did a handful of track days with the car.... but for the most part it was just a bad *** street car.
$34K obo
Location San Ramon, CA
gnx7 at hotmail dot com is best way to reach me.... or simply post questions on here
ID:	430182   Click image for larger version
ID:	430183   Click image for larger version
ID:	430184   Click image for larger version
ID:	430185   Click image for larger version
Old Oct 12, 2015 | 08:07 PM
1BADBURB's Avatar
1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !
Holy mother of god. That is uber bad ***! Glws!
Old Oct 12, 2015 | 08:08 PM
gnx7's Avatar
I have more pics for an interested buyer. With a rear wing and a track dedicated front splitter the car would be a monster. It has gobs of power at nearly any RPM and obviously a large rubber footprint. Totally streetable.
ID:	430190   Click image for larger version
ID:	430191   Click image for larger version
ID:	430192   Click image for larger version
Old Oct 13, 2015 | 10:18 AM
Dick Fidd's Avatar
Dick Fidd is infamous around these parts
How is this not better than a ZR1? Fixing stuff all the time? More luxury? Awesome car - and I'm local... don't twist my arm...
Old Oct 13, 2015 | 11:16 PM
gnx7's Avatar
Well... The zr1 does have launch control... And it can run a mild cam and still make 700rwhp/tq on e85. He just is ready for something new.
Old Oct 16, 2015 | 01:32 PM
gnx7's Avatar
some video links I found.
Vs. a stock GTR that ran 10.8's
go to 2 min 30 sec. 10.9 pass on the RA1 tires in road race form (it makes more HP now due to the straight shot intake)
Old Oct 26, 2015 | 06:01 PM
gnx7's Avatar
to the top for monday!
Old Nov 20, 2015 | 11:32 AM
gnx7's Avatar
Friday bump
Old Dec 5, 2015 | 02:10 PM
gnx7's Avatar
weekend bump.
Cold start issue resolved. new plugs installed and had the tuner play with the tune. In the high 40*F's!
Price drop to $38K.
Will trade plus cash on top for 2010+ ZR1 with good options.
Old Dec 6, 2015 | 07:44 PM
slowzzz's Avatar
slowzzz is infamous around these parts
The holy grail of swapped RX-7's. 10.9 @ 133 on 91 octane, that's a smoking fast time! GLWS.
Old Dec 9, 2015 | 01:51 PM
Stiman5781's Avatar
Stiman5781 is infamous around these parts
Still for sale
Very interested wonder still for sale I emailed you can u get back to me thanks
Old Dec 10, 2015 | 01:46 PM
gnx7's Avatar
replied to your email. Thx for the interest!
Old Dec 30, 2015 | 11:26 PM
gnx7's Avatar
hump day bump! Price lowered to 38K
Old Dec 31, 2015 | 12:15 AM
awd>'s Avatar
awd> is infamous around these parts
I wish here was a way I could get into this car. So much want!
Old Jan 21, 2016 | 10:05 PM
gnx7's Avatar
to the top! Happy 2016
