1994 toyota supra
Old Nov 16, 2017 | 08:15 PM
Inline6turbo's Avatar
Inline6turbo is infamous around these parts
1994 Toyota Supra Original TT 6 Speed Car
Year: 1994
Make: Toyota
Model: Supra
Price: $70000
Mileage: 1500
Color: Quick Silver
Location (State): FL
Transmission: Automatic
Drivetrain: Rear Wheel Drive
ENGINE
-Built 3.0L: Short Block Assembled by (TEC) Total Engine Concepts (They do all the work for EKanoo Racing and Titan Motorsports)
-Carillo Rods, JE Pistons, Titan Billet Mains
-Kelford 272/280 Cams
-New cylinder Head w/ GSC +1 Valves
-Dual Valve Springs
-ARP 625+ Head Studs
-Precision GEN 2 Billet 7685 Turbo
-Dual Tial 44mm Wastgates
-Tial 50MM BOV
-Polished 6" ETS Intercooler
-Polished Hypertune Race Intake
-Polished Hypertune Fuel Rail
-FIC 2200 Injectors
-Weldon 2345 Fuel Pump
-Weldon 14000 Controller
-Weldon Regulator
-Full 4" Exhaust
-Nitrous Pro Flow Kit Jetted for 125 shot currently (Installed but never used)
-Polished Koyo Radiator
-Polished 5" Intake
-Powdercoated Valve Covers and Rad. Hard Pipe
Transmission & Rear End
-ATF Th400 Built for 1500+hp. Transmission has less then 250 miles
-ATF Billet CNC Valve Body with Internal Transbrake
-ATF Billet Aluminum Drum with Promod 36 Element Sprag
-ATF SFI Approved Steel Flex Plate With ARP Bolts
-Red Alto Clutches
-Billet Triple FTI Torque Converter to Induction Performance Spec's
-B&M Ratchet Shiftier
-Dual Trans Coolers
-Driveshaft Shop 9" Rear End Kit w/ 3.70 Gears (Over $8,000 alone with install)
-Driveshaft Shop Driveshaft
-Driveshaft Shop Axles
-Still has clutch pedal in the car if you want to convert the car back to a 6 speed
Suspension
-Tien Coil-Over Suspension
-TRD Sway Bars
-Weld RTS Wheels 18x9.5" Front, 15x10" Rear
Electronics
-Pro EFI 128 ECU Tuned by Alpha at Induction Performance
-Flex Fuel, Traction Control, Oil Pressure, 5 Bar Map Sensor, ETC.
-Color Can Logger Display
-Pioneer Navigation
-Upgraded Polk component speakers and sub-woofer
Misc
-98 Headlights, 98 Tail Lights and 98 Turn Signals
-Rear Wing and Wiper Delete
-Battery and Fuses Relocated to Rear
-New Window Moldings
-Dakota Digital Speedometer adapter
-Upgraded L.E.D. Dash Lighting and interior lighting
-GPS Rear View Mirror
-All Power Options Work, Ice Cold A/C, Power Steering, Power Windows etc.
Car is an orginal Twin Turbo 6 Speed car. Chassis has 120k and less then 1500 on the new setup complete. New paint is less than a year old. The car was completely stripped and redone. You will be hard pressed to find a better street/ strip car. Especially one that will appreciate in value.
The car made 1040rwhp @ 30 PSI Tuned by Alpha at Induction Performance. Car will make more power if you want to turn it up to 50 PSI. With it currently at 39-40 PSI with the Pro EFI is estimating power around 1300whp. This is a car you can drive to the track, run 8's and drive home with the A/C and stereo cruising. This car is completely sorted out and needs nothing unless you want more power. With a larger turbo the car could dip into the 7's. This is not a fire sale and the car is located in Pompano Beach FL. stored in my A/C warehouse and only comes out to play when the weather is nice outside. These cars are only going up in value and I just don't have time to use the car like I had planned.
ID:	516164   Click image for larger version
ID:	516165   Click image for larger version
ID:	516166   Click image for larger version
ID:	516167   Click image for larger version
ID:	516169   Click image for larger version
Old Nov 17, 2017 | 04:14 AM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
very nice! best et/mph? is the tranny reversed valved or just fully automatic? thanks
Old Nov 17, 2017 | 12:51 PM
JRHorne's Avatar
JRHorne is infamous around these parts
You make no mention as to if the car is an original 2JZ or an NA that you built. Probably a big consideration.
Old Nov 17, 2017 | 01:17 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
super clean build, nice job.
Old Nov 17, 2017 | 07:27 PM
Car has been 8.8 at 165mph on the old setup and a soft 60'. The new setup makes the same power at 35lbs as the old setup did at 48lbs. Transmission is a reversed manual valve body.
Old Nov 17, 2017 | 07:29 PM
Car is an original TT 6 speed car. Still has the clutch pedal under the carpet if the new owner wants to convert it back too a 6 speed. Will update original post.
Thank you.
Old Nov 17, 2017 | 10:47 PM
arjayr33's Avatar
94 supra
would like to have further chat tomorrow here's my cell (856) 426 9607 shoot me a text since I can't send you PM yet. thanks
Old Nov 22, 2017 | 07:27 PM
Sent you a text.
Price is obo.
Old Nov 28, 2017 | 09:59 AM
Update first post with new price. $70,000
