Sagging Headliner on PanS
Hi guys! Any of you have a sagging headliner? Very soon the headliner fabric in front will cover my eyes and will touch the head of my passengers at the back seat as well. Help how to repair this pls
I too had the same problem, but my headliner was falling off on all sides. I had to take it into a trusted place to get the old fabric taken out and replaced with new fabric. The place I chose used a material that is basically the same as what the car came with. Once you redo it, it will look and feel amazing compared to the old, weathered and unglued headliner. I paid around $800. Hope this helps!
Thanks thefullgarage! So they did not use the old fabric? Did it look exactly the same? I was contemplating on doing the same but worried that it will not look OEM and will diminish the value of the car. Hope I can find someone who can do a good and clean job.
Hi guys. Does anyone have a link to a DIY on taking out the Pan headliner? I watched a YouTube video how to take down the headliner of a Cayenne. Is it the same? My last Cayenne was a 2006 model so I wouldn't know if the newer models are the same as the PanS. Planning to DIY the taking down of my headliner so that I can just bring it to the upholstery shop and have it repaired.
I don't want to risk a windshield removal and would like to try all aftermarket options before considering a painful $5k replacement by the dealer with warranty
I'm also interested if anyone has had any success with this DIY removal on a Panamera. Similar to you, fullmetaljacket, I have an annoying headliner sag that recently started in my passenger rear that will require full attention in the near future. I've visited several shops in the Atlanta area but none of them will touch it or they don't meet up to my standards. There were two shops willing to do it but they both said the windshield would have to come off Reason being the large size of the headliner compared to the restricted space/small openings of the Panamera. Avoid any buckling of the mat.
I must be the only guy without headliner issues. Is this happening to anyone with alcantara? (GTS/Turbo) I have a turbo with Espresso interior and the headliner is a touch lighter almost like a grey/espresso mix and I'm worried IF something happens there is no way to match it without sourcing OEM material.
I found an online manual that describes removing the passenger seat, fold down both rear seats, detach headliner and remove through the back. I'm curious if anyone has had any success following those steps before I try.
I don't think it is a common issue or else there would probably be more info when trying to search online. A bit aggravating for me because the car's been garage kept it's whole life with limited use and this happens... OEM alcantara might be hard to match however, one of the shops I visited here had a huge array of ultrasuedes to match up. The problem was going to be matching the fabric. Hoping to get some input from thefullgarage on his experience.
mine is garage kept as well. Maybe it's the moisture.
I think it can be done through the rear hatch as well and most likely how the dealer would do it. However, the independent shops know the price of a new headliner from Germany so don't want to take the chance of a buckle.
Saw these YouTube videos on taking down the Cayenne headliner and dome light console. Wondering whether the process is the same hmmm...
Also found pictures on FB that gives ideas that it can be removed without taking the windshield off and also where the bolts are located...
https://m.facebook.com/story.php?sto...20738444697859
Are these information enough for me to attempt this job??
So here goes for the benefit of fellow Panamera owners with sagging headliners! will post step by step with info in clips and panels to take out for this job when I'm done...
