Tech / How To
Escort 9500ci installation help
Old Feb 2, 2011 | 06:16 AM
2020's Avatar
2020 is a splendid one to behold2020 is a splendid one to behold2020 is a splendid one to behold2020 is a splendid one to behold2020 is a splendid one to behold2020 is a splendid one to behold2020 is a splendid one to behold2020 is a splendid one to behold
I am thinking about installing this radar detector myself on a 2011 Cayenne. Just need help deciding where and how to get the wires from the engine compartment to the inside of the car. Also the best way to power the unit in regards to the fuse box. Any help would be appreciated.
Old Feb 2, 2011 | 08:44 AM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
I would use an add a fuse in the glovebox, that will be the easiest way for power (auto parts stores have them for about 10 bucks). As far as getting the wires into the inside, you will just have to find some of the rubber body plugs and pick one to go through. Just cut a small X to pass the wires through, then silicone them when you are done to keep everything water tight.
Old Feb 16, 2011 | 08:39 AM
jmc777's Avatar
jmc777 is infamous around these parts
Use one of these... Easy safe and reversable
http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
007AMV8
Oct 19, 2015 09:55 PM
MadWhip
Sep 3, 2015 02:04 PM
